Funky Fuel Injectors?-*UPDATE*
TYRODD
My ass. Look at it.
OK, been smacked with more crap. Have very wacky cold start up problems like bad flutter, stalling, and other fun things. Truck hiccups like crazy until after 2000RPM-then things are smooth. After the truck runs for a while, even after completely warmed up(it can take a WHILE), the problem completely dissapears even the crappy idle. Ive replaces the plugs, wires(with delco's), MAP (this was bad), cap, rotor, and just about everything else that could cause ign. probs. I have checked things very thoroughly. I suffer from the Huge vac leak from the TB shaft-which really shouldnt cause a real problem. As far as Ive checked, the vac. system is tight as a drum otherwise.
Back to the subject at hand, I just got through checking injector pulses with a tester, this is what ive found:
All tests were done with key on, fuel pressure a 43psi (base), and tester set at 50 pulses. The injectors are stock.
#1 dropped to 22#
#3 dropped to 28#
#5 dropped to 22#
#6 dropped to 22#
#4 dropped to 30#
#2 dropped to 23~24#
I have very little experience with injectors, but #'s 3 and 4 seem pretty funky. Could anyone agree and or give me some help.
-RJ
psych-lone
Only feasable option I can think of would to have the injectors flow tested. Other than that, find somebody to swap a set with. Try clearing the codes as well, also sounds like a dirty IAC. Good luck.
TYRODD
My ass. Look at it.
Bummer, I live in nowhere, you know where thats at right? :D The only other ty in town is owned by a dude that could care less, its garnet(rare) he also owns a GN which also looks like feces. The IAC is new and everything was cleaned thoroughly. No codes either. I have a feeling I will be pulling them all out soon, as well as the upper intake, so I can give them a good cleaning.
Danke,
RJ
psych-lone
Well, if you think the vaccum leak at the TB is a problemo, try squirting it with some brake cleaner while the truck is running. If the RPM's shoot up a bit, there is a defenite vaccum leak. These trucks just seem to be a little cold blooded to boot. Did the problem arise suddenly or gradually over a period of time? What other symptoms does it have? Checked the timing? Possible that its a bit retarded.
TYRODD
My ass. Look at it.
Well, the location of the leak would probably cause more of a boost leak rather than a vac. leak, I cant suck carb cleaner in to check. Timing is fine, its a problem that fixes itself the longer I drive it, like if the injectors fix themselves. Asked a GM tech about it today, and he said it was definitily a prob. and that it could cause the symptoms I have. Prolly need to clean the injectors, but hard to find time to do something like that, especialy since its a DD. If it was a vac. prob. or ign., I dont think it would fix itself.
Ian Turgeon
Cascading Inspiration
grab a stock set off a board member, and ship those out to be cleaned/matched.
oh yea, and i have some for ya, your $ so you tell me how much their worth to ya.
TYRODD
My ass. Look at it.
Well, I ran a few more tests tonight, and found some more mysteries. With the fuel rail primed to 43# and key off, I lose 10psi of fuel in ten minutes. I also noticed it leaks very slowly from 43-40, but at ~39 it drops off fast enough to watch the needle move. I tested this several times, and actually on the first test, engine cold, I lost 10# in twenty minutes. After starting it and letting it run for a few, I was losing 10# in 10. Also the needle on my FP guage flutters pretty bad, at Idle it flutters about 4psi either way, even when I get on the throttle a little. FUN FUN FUN!!!
TYRODD
My ass. Look at it.
Lost a little momentum today. I was going to have my injectors cleaned and flow tested/matched, but no one can do it here in this hell hole. Looks like I'll be buying 2 or 3 new stock injectors @ $85 apiece. I'll have the upper to lower intake gasket in tomorow so if I can get the injectors then, I will be having fun tomorrow night. This shits adding up fast, I guess it comes with the territory. :-? :x
TYRODD
My ass. Look at it.
Well., I installed the two injectors, cleaned the others as well as the entire upper intake and throttle body, IAC, MAT Sensor, well everything above the lower intake and all I can say is WOW, it was durrrrrty. Appears that all this has fixed all of my known problems, the idle is as smooth as a babys butt now so dats cool too.
The Injectors I replaced had no physical damage to them, the "nozzle" er...the plastic/ceramic hoodis was fine as well. All the injectors are now flowing equally as far a I can tell with a pulsator and FP guage.
Yay for me :lol:
smeagol
FWIW, or for others' benefit.. i would have just sprung for Delphi injectors from PTE or Mike etc. Methinks they are in the range of 300 bucks or so for 6 brand new matched ones.
TYRODD
My ass. Look at it.
Yeah, I though about the Delphi's, but feared the cost. Dammit, wish I had known about those earlier, it would have been about $250 cheaper than a new set of stockers($547)
I was surprised at how little time it took me to do this all, only about 3 1/4 hours, the cleaning took the most time, used 2 cans of BG (having to go get the second mid job as well as a few other "arrands")and a wire brush(not on the injectors! :D ). FYI this was my first time ever to take the Upper/fuel rail/injectors off the typhoon.
