fuse box connector
gjp
another post whore
there are some open areas on the fuse box where I can use a commector to tap for power. looks to be a black plug in connector there on some spots already. where do i find the stock type plug in connectors?
Bill Z
Re: fuse box connector
These trucks use the regular bayonet style connector that can be purchased at any automotive parts house, Wal-Mart and other fine stores.
Some of the spots on the buse box are hot all of the tima and others are switched via the ignition. Test to make sure you are getting what you want.
Hope this helps.
Good luck.
epix
Typhoon
they are just called fuse taps, you should be able to get them at autozone, napa, etc
gjp
another post whore
the ones on my truck look like they have a clip that lock in. The ones at autozone can come out easy.
