Fuzzy Boost Controler
1992Typhoon
When I purchased my Typhoon it had a Fuzzy Boost Controler on it already. It has been functioning flawlessly until this weekend. I am now getting an overboost condition that I can not program out of the controler. It still reads all vacuum and boost. Does anyone have this controler and seen similar problems. If floored it will boost out of control and cause detonation at approximately 19.5 pounds. I have never set it above 15.4 to date and yet now it will climb out of control. It continues to read good vacuum (-17 pounds at idle in neutral and -13 pounds in gear at idle) so I doubt it is a vacuum leak. The overboost is the only problem of any kind. Any help is appreciated!
BillC
Since it seems to have happened "suddenly", and the unit seems to be operating, you should check mechanical causes first. The most important thing to check are the hoses to/from the control solenoid. If there is any leak or crack, your boost will be uncontrollable. Just because the unit reads boost & vacuum correctly doesn't mean the hose to the wastegate actuator is still connected or intact.
1992Typhoon
I checked it all out and you were right! The hose to the wastgate actuator was off. It must have blown off under boost, that is when I first noticed the overboost condition. It was completely hidden and looked like it was still connected until I reached in and it moved real easy. Thanks for the help, ikt is once again working like a champ. It is so nice to be able to adjust the boost at any time!
