4C FED
Absolutum Dominium
I'm learning more & more as I work on my "built" rebuild.
I learned today that if the block and heads aren't surfaced with the right finish, that head gasket failure is very likely.
I was told today that the surface finish on my block was to rough and that someone used copper sealer as fill to make up the difference.
So now my block & heads need to be re-surfaced with the correct finish.
Anywhoooo, here is a link regarding surface finish:
http://www.federal-mogul.com/cda/content/front/0,2194,2442_7359_7477,00.html
