FYI DIY WB parts problem
myclone
I built two DIY WB kits a while back and ran into a little snag on one of em and thought Id post it FYI.
While doing the check out steps located here: http://www.diy-wb.com/diywbchk.htm I ran into a problem at step 12 ("Measure voltage at U3 pin 5. Verify 7.9 to 8.0 volts. If not check ISO1, R38, & C12."). I was getting 7.3v here instead of 7.9-8.0 volts and this being the power supply for the ckt I figured it would throw the linearity of the output signal off. I did the checks that are listed on step 12 with no probs noted and finally tracked it down to the output of U5 (the 7808 8v regulator). I thought that maybe something in the ckt was loading it down some so I pulled the output leg out of the pc board and measured the output of U5 with no load. It was 7.3v.... I swapped U5 with another regulator I had on hand (working in a electronics maint shop has its advantages :wink: ) with the same result.
Im scratching my head now thinking WTF can be wrong with this thing!!!?? Theres a zenor, 2 caps, and a resistor so something else is dicked up (yes, I checked for solder bridges first). I swapped out the zenor thinking it may be leaking or something. Nope... Same prob.. Did the caps too.. Same problem... Checked my DVM for accuracey.. Nope.. It was +/-150 micro volts. Scratched my head somemore and figured what the hell... I swapped U5 outta the other kit that was done and worked fine.. TA DAHHH.. 7.98v. WTF!!!! Come to find out that I had two crappy 8v regs that were brand new (just my freakin luck). Swapped in a third 7808 and BAM... 7.9 volts out..
So..... All that rambling just to let you DIYers know that when doing step 12 in the check out of the ckt to make SURE that the 8v reg is doing its thing. If its not pitch it and install a new one. If it still isnt right pitch that one and get another as the 7808s dont seem to be very accurate IMO.
