FYI UV Erasable Chips
This is alteast the 6th chip I have seen with the UV erasing window left open.
UV Eraseable PROM's, like the stock chip and the Ultimate Chip, are UV erasable and should have a stickers over the silicon chip window. If it is expose to sunlight, the UV rays from the sun will flip bits to 1's which basically meaning its starting erasing the PROM.
Loeryder
Re: FYI UV Erasable Chips
Great!
I need to check my extra ult and my stock memcals to make sure they still have stickers.
thanks for the TIP!
thewumpus99
FYI, a few hours of exposure to daylight or indoor lights is not something to worry about with these (likewise, if your computer is shoved up under the dash, there's not going to be enough UV light to start the erasure process). The erasure units they use to totally reset these PROMs is a *very* intense UV lightbox, and takes 10-15 minutes to reset all the bits if I recall (it's been awhile since these PROMs were state of the art!)
However, exposure to direct sunlight for more than a few seconds is a Bad Thing (you only need to reset the weakest bit on the chip for contents to be corrupted). Also, you don't need anything fancy to cover the chip windows up... we used to use little address-label-sections in the industry, but this was only so we could write version information on them. Electrical tape should work fine too.
Tooky
Serious about performance
Great tip Dave, I have also been surprised with how many times I have seen someone do this. Be careful!
I agree that a a few minutes isn't going to reset the bits and they are safe with ECM back under the dash is safe, however most owners have no idea that it can be erased. I see them on the work benchs, near windows, interior center consoles and with the ECM hanging. Overtime these palces could be slowly erased the PROM if hit by sunlight.
I have seen them flip a few bits and have a corrupt .bin. The owners have no idea and if they were burned by a chip burner, the chip burner should cover the window or atleast warn the owner not leave the PROM in direct sunlight for any length of time.
Ty 1885
Oh man, will an xray cause problems ? Anything comes in the mail, UPS, est. gets xrayed.
Loeryder
X ray does not contain UV rays.
They are a step further down in wavelength.
