gages
Typhoon #1133
What gages does everyone recommend for my truck? boost, tranny, fuel pressure. all of them? any others? Also, where is the best place to buy them at?
Keith :roll:
turboj91
SPA Digital is the only way to go. 2 readings on one gauge, Digital (no guessing of EXACTLY how many lbs of boost, fuel pressure or temp and they have a high recall button. (it will tell you your highest reading obtained ((great for boost spikes)). They are expensive but worth the $$$. Anyone in for a GP. 2 gauges will get you 4 readings. Everyone (IMO) should have boost, fuel pressure, I/C temp and I think that leaves another temp (trans. is a good idea). Website is SPA Digital and there is a distributer that sell them about $10-$15 cheaper than what is listed on the site. I need a set (and a Lotek pillar pod). GP GP GP GP GP GP !!!
InvisiBill
turboj91 said:
SPA Digital is the only way to go. 2 readings on one gauge, Digital (no guessing of EXACTLY how many lbs...
Analog is nice in that you can tell at a glance about where you're at. Like how straight up is 60mph on the speedo... With digital, you have to interpret the number. I've always liked the ones with an exact numeric readout, as well as a sweep for at-a-glance readings...
Richme
Well, that's what the SPA gauges show, an exact number. Check it out.
http://www.spa-uk.co.uk/design/instru7.htm
Regards,
InvisiBill
I was referring to the digital gauges that also have an analog sweep too. I've seen them for speedos somewhere... Ex's Cutlass Supreme maybe?
The analog is nice in that you can see where it currently is relative to the whole range. At a glance, I can tell if I'm at +10 or -10, as they're almost 180 degrees apart on the gauge. On a digital gauge, it would be easy to miss the - with a quick glance, or misinterpret 68 for 88, or something like that. They both have their pros and cons... Which is why I like the ones with both a number readout and the sweep around the edge. You get a precise number, but can also tell at a glance if you're at 1/4 or 3/4...
Richme
Oh, I understand, that does sound sweet.
TurboManiacal
BillC said:
Actually, it is spelled "Gauges". MR_MNZTR_SY had it correct the first time.
Dang I fell off the horse on that one.
tr.v. gauged, also gaged gaug·ing, gag·ing gaug·es, gag·es
To measure precisely.
To determine the capacity, volume, or contents of.
MR_MNZTR_SY did have it right I was more refering to the GAGES...apparently though...upon further research...GAGE is also correct.
gauge also gage Pronunciation Key (gj)
n.
A standard or scale of measurement.
A standard dimension, quantity, or capacity.
An instrument for measuring or testing.
