gas tank cleaning flush?
cloneman315
I got a used 13 gallon tank and it is nasty inside,anyone know of the best way to clean it?any products or services out there?
Norm
Re: gas tank cleaning flush?
rust or just sediment/junk? My buddy owns a rad shop, when he cleans them out he uses dishwashing soap and a pressure washer.
cloneman315
thats what I was thinking,this tank has a plastic type wall system in the tank,you think it will be ok?
sy#2716
SyTy 4 Life
I just used alot of soap (i used a full bottle of cheap dish soap one of the big ones) and water. I washed it out probaly 10-12 times before the smell was gone. Mine was nasty as hell also when i got it out of the junk yard.
warmpancakes
dump some kerosene in it and let it sit over night you could just stick garden hose in it and walk away for a hour or so
WyoSyclone
the gas has turned into varnish on the walls it looks like
You might take some Stabil and see if that will help dissolve it. It may take letting it soak for a while, then if you have a pressure washer with some Simple Green mixed as a strong solution that may do it. Chevron makes a cleaner that will take ANYTHING off and they claim it's OK on most materials. I've got some in the shop... let me look at it tomorrow and see if it'll be OK for the plastic that is in your tank.
