gaskets
ocgmo
93phoon
I have vortek heads and was wondering if anybody had the felpro part number, or a better gasket number. i was told Mr. Waller did the intake mods on my truck. If you are reading this it is 93 Ty formerly owned by Mr. Calcagno. thanks for any help.
ocgmo
93phoon
Re: gaskets
thanks for the help, i will check with Napa. is the 1203 a felpro number that Napa will recognize?
Re: gaskets
Is it safe to assume that you are wanting the intake-to-head gaskets?
Correct me if I'm wrong.....
Just get the ones that fit '99 Sonoma w/4.3L and you're good to go.
You will have to make holes for the bolts and use some sealant around the areas.
I have a set in storage, if you need me to take a pic or get the number let me know.
Tooky
Serious about performance
Re: gaskets
Everyone uses the 1203 gaskets because (among other reasons) you don't have to drill holes through a gasket sealing surface and run the risk of leaks. I would be willing to bet money that Waller ported Calcagno's vortecs to the 1203 gasket as well.
