gaspedal stuck at wot??
93ty475
has this happened to anyone? I asked someone about this and they said it was the floormat...so I yanked the floormat and it happened again....doesnt happen everytime I go wot, maybe 1 in 10 times.... and I can't seem to simulate the occurance while stopped with the engine off....scary stuff....I'm sure it's an easy fix, just curious if anyone else has experienced this and what the solution was....
VermontTy
Support Our Troops
Re: gaspedal stuck at wot??
Dang. If you take the TV, cruise and throttle cables off the throttle body, is there ANY hangup whatsoever just running the butterflies with your hand? Might want to take off the cruise cable (if you still have cruise), and see if you can get it to stick again. Then try removing the TV cable (dunno how it would drive with it disconnected and WOT) and see agian.
Its gotta be something simple like a burr or poorly lubed cable. Everything look kosher down where the pedal hinges?
Are your sy seats not as faded in color anymore?
:rant:
93ty475
I know the butteryfly moves freely without cables attatched....and this one has all three on there, even cruise control....I just need to spend some time on it....talk about catching you by suprise!!! we were messing around in my parking lot at work last night (with a video camera) and I tried a launch.....I'm not very experienced in launching, well, it got stuck again....I totally locked the brakes up as soon as it launched!! scared the crap out of me as I was in my small parking lot...
Next time, try doing a boosted launch in a bigger parking lot, that is like doing a boost launch in my driveway :rotf:
Usually when those style throttle plate bind from worn bushings, they bind at 1/4 throttle or less when closing. I had a car that was sticking at WOT, scary stuff, it was sticking on a hose clamp that I had spun around 90 degree. Check to make sure their is no way something can stick on your throttle linkage.
93ty475
well at first it was just going to be a video of the truck idling, then I thought I'd spool it up a little, then little horns grew on my head and you know the rest....weird how mashing on the brakes HARD dislodged the stuck gas pedal.... :D
Well the truck sounds nice. TV cable shouldn’t do it, cruise might but I doubt it. Is cruise off? TPS won’t. Take the TB off the truck and take a real close look at it. Shaft play? Both return springs functional? Before you do that though, as Dave said, I’d suspect something catching the throttle cable/pedal where they connect under the dash. Get on your head and look real close up under the dash while you work the pedal. However, what you're saying is engine torque is causing the prob. so look at what might be causing things to bind up with the engine torqued over.
crazykaese
91ProtoTy/IndyPaceTribute & Sawzall Master
My throttle got hung up due to a boost launch and a broken driver side motor mount. Boosted ->motor kicked up -> hit bottom side of hood -> bent metal a/c line into the flat 90 degree elbow bracket of throttle -> pinned it at full throttle. Pedal stuck to floor -> gaining on traffic quickly -> think fast -> turned off ignition -> hung on for dear life. Got it stopped after using shoulder to avoid traffic. Good thing my truck is still stock motor - woulda wrecked the darn thing otherwise.
I have since replaced the motor mount and strapped it down.
Check your motor mount dude.
93ty475
good point man....but this is my stock turbo/engine truck!! I built a stock motor for it and put it in....can't be motormounts because it has J&S solid pads and mounts in it....I'll dig into it and get to the bottom of this asap.....hard to think fast when or if this happens!!
Well so much for my idea about engine torque.
Let us know what you do find out.
What might be worse than a stuck throttle? Brake failure on a steep hill in a old Caddy many years ago. Did a intentional spinout at a wide spot to get it stopped. Never forgot that one.
93ty475
sorry don, I overlooked your previous post.. :oops: no doubt it's a bad problem....weird that it only happens 1 out of ten times...can't get it to stick when I need it to....I thought the problem was fixed after removing the floormat earlier...I'll let you know what it was when I find it... :tup:
93ty475
tippmann243 said:
sorry to whore but what kind of exhaust are you running
I'm running 3" press bent mild aluminized all the way out to the back....no cat and no muffler....I'm fabbing up a 3" mandrel downpipe using a J&S stock turbo flange in the next week or so....the truck runs awesome...only mod is alky and a custom alky chip...23 psi, no knock!!....no overboost due to darons helpful little secret... ;)
SYO237
SyTy Registry
Dont really have an answer, but I do remember Ivan the Terribles pedal getting stuck in his floormat in a parking lot. He ended up getting it unstuck, but only after he put his Syclone into a side of a building to stop it.
Project Menthol Marlboro began shortly after...
93ty475
ouch...that had to hurt....its a very unnatural feeling to let go of the pedal because you want to slow down instead it starts pulling like mad due to a turbo further spooling up.....I just got under there again and looked and nothing really jumped out at me as to a probable cause....hmmm
I still say take the TB off and check it. However I just took mine off (for different reasons) and was just looking at it ‘cuz of you and really can’t see anything that might cause it to stick. The return springs are fairly strong by themselves. There are two so make sure you have both working. Try disconnecting the throttle cable at the TB and see if it moves free. It will prolly stay down by itself this way but you should be able to pull it back with simple finger strength. Maybe the cable is going bad?
On the back side (rear) of the TB is a little lever that operates the TPS. Make sure something isn’t getting cought there.
Frustrating
SY2932
Administrator
I had the misfortune of having this happen to me once in the early spring. I was cruising down the highway and got on it to get around a slower moving car before I got boxed in by another one. Took my foot off the gas and the truck kept accelerating... I tried to lift the pedal back up with the tip of my shoe. I managed to lift it up but it had no effect whatsoever.
By now, I was pushing 100 MPH and was about half a mile from a traffic light that was red. I started applying the brakes to try and bleed off as much velocity as possible but it was futile. By now, I had my hand on the ignition and was prepared to kill the ignition when out of desperation, I stomped the throttle all the way to the floor. That did the trick and disaster was averted. The whole event only lasted about 4-5 seconds but it seemed MUCH longer than that. Pretty amazing how many things can go through your mind in such a short period of time all equal in intensity...
Back home the throttle body came off and I sprayed some penetraing oil around the butterflies and linkage and haven't had a problem with it since.
