i converted an s10 over to a complete interior wiring harness from a SGT and am now chasing wiring gremlins.
the engine harness is all new, i just put it together, making sure everything is in the right spot.
i have the big black wire for inst. cluster, grounded to back of cylinder head, and made sure 3 times it's grounded well, the entire strand of oil pressure and coolant temp sensor wiring is all new, and both sensors are new.
oil pressure will inconsistantly work and then not, tried 2 different gauge clusters, both are low mile clusters, both around 50-60k, 1 was SGT cluster from the same truck as interior harness and the other is a spare syclone cluster.
no change, gauge is sporadic, will read correctly and then will not read at all, if i unplug the sending unit with key on, the gauge needle flips all the way around.
the coolant temp sensor refuses to work, ever, sometimes it will peg when i ground the plug and other times it won't, but plugged in or unplugged it always lifts off the peg about an 1/8 inch when the key is turned on. i just went and exchanged the new sender for another new one to see if that cures that issue but i doubt it.
the voltage gauge reads very low, around 9-10, i am switching alternators out tomorrow to see if that cures that or any other problems.
i've successfully grounded both coolant temp and oil press senders a couple times so i do infact know they are in the right spots going through the fuse panel.
what is it here that i am over looking?
