getting code 43 and need help fixind the problem
syclone#2659
hey guy im getting the code 43, how do i fix this .....i read the sy ty archives and i have no clue as to what there talking about , im not the smartest guy when it come to electrical. what do i have to do to fix this? also ive been having the problem of hesatating from on the go from a stop...normal driving and it seems to do it all the time, when i step on the gas it goes fine for a sec and then it stumbles " kind of looses power", and then goes fine again for a second, then shifts into 2nd gear, i dont notice it when i go super slow off the start, or when i floor it off the start. could this be related to my code problem to? please help
Ty0279
Historically Significant
It's your f'ing ATR Pit Bull chip.
Get rid of yours, like I did with mine a long time ago, and the problem should be solved.
syclone#2659
it was just rebuilt 2,000 miles ago, brand new conrad cap and rotor, atr black beauties, new cr42ts. any one know about the codes? and about the chip do you really think that is the problem? should i reset the ecm
ABLITZ
Damn Yankee
i'd try some NGK UR5's.i switched from the NGK's to the AC's and it brought out a stumble like yours.with the UR5's it ran like a top.IMHO the NGK's are alot better.
Ty0279
The symptoms you're experiencing sound exactly like the ones I was having with that chip. A friend diagnosed the problem for me (along with Datamaster :wink: ) and we switched out the Sh*tbull and replaced it with the stocker, adjusted the FP and then we were good to go.
Your mods are much more extensive than mine, but looks like you need a performance chip, not the stocker.
HTH
syclone#2659
see the thing that is weird is it just started doing this within the past week, i really cant go back to stock because i dont have stock injectors and every thing is to darn big now, i reallly need an 50 lb ultimate and the 3 bar, maybee my gap on the plus is to wide?
KGB Pilot125
you need to get a new knock sensor, this is causing your code 43, then get a stock cjip or 50 pound ultimate, then do a tune up.
the reason its stumbling when you get on it hard is the computer is pulling timing because the knock sensor is messed up so its going into a safe mode
Syclone#1992
SyTy.net Moderator
Get that Shitbull out of there!!! :wink: I had the same problem....at some points in datamaster my knockretard was at 15 degrees....NOT good :roll: It scared the shit out of me.
Took the chip out like everyone reccomended...and I get 1-3 degrees of knock at the most. I was told that the ATR Chip leans the truck out and that is what could be causing the knock retard . I would not recomend this chip . Put the stocker back in and see what happens
