Re: getting no action from my fuel pump
TYRODD said:
yes, or you can just connect it to the junction block to the left of the relays, its also 12v. Much closer
If your pump doesn't run after doing this, it is dead or you have a bad ground. There is a remote possibility that your power wire could be bad as well. However, that usually isn't the case. The ground wire for the fuel pump is connected to the top of the sending unit and it connects directly to the top of the frame near the filler neck. The fuel pump test connector is a
DIRECT connection to the fuel pump, it will turn the pump on even if the ECM B fuse is removed/blown.
"Applying 12 volts to fuel pump test connector to troubleshoot fuel pump or set fuel pressure with vacuum line still connected and motor off (note fuse for safety)."
