Getting ready to do the EGR delete
2_60b4u
Looking for 12's
So, I bought the EGR block off plate, and read the instructions on the syty archives.
My question now is: Can I remove the EGR parts without having any negative effect running the stock chip/tune?
Flyin Ryan
hated cuz he drives fords
Re: Getting ready to do the EGR delete
aside from removing the egr solenoid and blocking it off you also have to disable the egr function within the tune on the chip your using or at curse speeds you'll get a check engine light and slight hick up in your throttle.
jwaller
Evil Genius/SyTy Guru
you will get the serv eng light every now and then. there are several ppl on here that can reprogram the chip to work around it. myself and mike hood are 2 programmers that can help you out.
That being said you, if you have the EGR disabled in the chip prgramming. You don't need a block off plate.
2_60b4u
Looking for 12's
Thanks for the quick response!
So, Is the block off plate just for appearance after It gets deleted on the chip?
jwaller
Thanks for the quick response! So, Is the block off plate just for appearance after It gets deleted on the chip?
yes and it makes working at or near the dist easier. it gives you quite a bit more room back there and you can also remove the lines and the solenoid on the other side of the intake.
