Getting Ready to Start the Winter Build
ZR1TR
I was hoping to just try to tune and tinker with the Ty over the winter but an ailing torque converter and a tired tranny looks like it will retire her for the winter. Since it's going to be out of service I want to go ahead and start getting bolt on upgrades. Here is my goal, to run 11s in a full weight Ty in street trim without getting into the motor (maybe a cam). I think this is a realistic goal.
Here are my thoughts on what I would like to do. I hope the rest of you will contribute your knowledge and ideas. And if someone has a proven recipe please share it with me.
1) I want to do away with the w2a setup and go a2a. I know some guys have run really quick times with the liquid, but I think from a preventive maintenaince stand point a2a is the best way to go.
2) Because I have had 2 turbo buicks, I really like the external wastegate setup and would like to go that route. I'm not sure what downpipes are available and how difficult it is to swap from the Mits turbo to a Garrett. New manifolds or just a flange adapter :dunno:
3) As far as fuel I have a Walbro an AFPR and 50# injectors. Is that enough fuel for mid-high 11s? If not I know turbo tweak has 80# and a chip for the Sy/Ty.
Obviously it takes a lot more than that to get into the 11s, but those are the biggies I came up with off the top of my head.:tup:
Thanks in advance!
e95 Ty
Re: Getting Ready to Start the Winter Build
Good luck with your build.....Feel free to pm me if you need any advise.
I personally like the idea of using the stock heads/cam with a moderately sized Turbo. Any change to heads/cam really should have a full retune, it changes the whole VE fueling map on map based ECM. If your looking for off he shelf solutions I think it's the way to go until you max out the stock motor.
I think you can hit your goals with a Typhoon if you don't mind run in Alky or Race Gas. It will a beefied up transmission. So while your rebuild the trans, I would also get higher stall TC. I would use a pte6262 or pte6062 (pte52), rpm sells external wastegate for the PTE style turbos (the PTE exhuast housing fits onto SyTy exhuast manifolds without adapters.) I like the 60# injectors, they have less production tolerance than the 50#'s. 50# can be a little finicky if your try to use an off the shelf tune.
ZR1TR
Quickstop, with these trucks I don't think you can set a budget you won't break:D
Seriously, I know it won't be cheap. I'm going to try to snag as many parts off the forum and then bite the bullet when it comes to the big stuff.
Dgoodhue, I'm all for alky. Had it on one of my Turbo Buicks and really liked it. What would I do as far as a downpipe? I'll definitely check out RPM.
I may buy a tranny off the board, so the truck my not be down as long as I thought. I am thinking about doing this stuff in stages, one because it is probably easier to tune just changing one thing at a time and the other reason being $$$$$$$$$$$$$$$$$!
Other than a 3 bar MAP, autometer boost gauge, Turbo Tweak Chip, fuel pump and AFPR the truck is stock. What would you guys recommend as the first step? Turbo, injectors?
Quickstop [UK]
Combating adversyty.
Oh man, you've got it bad :D :tup:
Having got the gauge, the chip AFPR and a fuel pump, you're gonna need a wideband AFR gauge first and foremost. (PLX is popular as is the DM 6 multi gauge)
Then I would suggest either 63# injectors and/or razor's alky kit (www.alkycontrol.com). New injector = a new tune whereas alky is less effort I think in terms of bang for buck but it's still gonna need a new tune as well.
I wouldn't say turbo as a first step because it needs so much other supporting equipment, namely the AFR gauge, the injectors/alky and possibly a torque convertor as well depending on the turbo and the exhaust housing size.
As for downpipe, people have been pretty fast with the stock downpipe. I want to say 10s but I am not sure. Not top of the priorities list unless you change turbo and need a matching dp.
HTH.
