GMC Typhoon 10.76 @ 133mph
autoaddictions
Re: GMC Typhoon 10.76 @ 133mph
Thanks Ralph !! Nice job as usual. Man you can here that beast push threw the converter bad. You can also here the converter lock up top of the track . Those where my first passes on a new motor and turbo set up.. Before the second pass my dump down tube dropped off. LOL
ViciousV6
400HP/550FTLB
In those runs it sounded like it was shifting where it should of been. Not sure why it was higher all of a sudden. You gotta be careful on that tree i see you pushing a as soon as you move the tree is tripping.
Even if you just do the front line lock, like i had to pump the brake once and then hold gave me twice the clamping force.
Ralph
Treymen
Wow!!! I gotta ask what your exhaust setup is? Sounded amazing!
autoaddictions
In these 2 videos its just dumping out the 3" down pipe. Most of the time i run a full 3" to a borla muffler straight threw 3"
inlet 4" outlet then 4" pipeing out the back.
Treymen
Sounds great. It really hooks up well also. Nicely done
