got a quick question... about the PCV system
GEN3Typhoon
There are check valves that go into the system... so it cannot pressurized the crank case. I think according to the instructions, the actual purpose of them is in case the engine backfired though the exhaust it would not cause any issues.
bdubb
I am teh kingpin!
I just bought two of these kits from Michael Hood last week. call him if ya need one eric.
myclone
Some have check valves some dont. If they do and you plumb it in anywhere before the outlet of the muffler then the exh pressure is just gonna hold the check valve closed other than possibly idle. If a motor has as much blow by as Es does with its ~2 inches of piston to cyl wall clearance and now barreled rings from that excessive clearance then it will still hemorage oil out everywhere worse than it did before since it cant get past the check valves.
Basically either system wont work for E unless he plumbs it into the exhaust after the muffler.
E-Rue
ok its official...... i HATE the PCV system. i have it all back together, just like a stocker, and its still leaking oil. this is really pissing me off. i noticed on the pic of hoovers truck, that he is using a vacume pump. any one have any experience with those? what about street use?
some people are suggesting its blowby...... i really hope this fancy new mccoy motor doesnt have blowby issues. i bet i have less than 10k miles on it. this whole oil leaking thing has been going on for a really long time, but its just never been this bad. before it was always just a drop or two around the PCV port. now it seems to actually be blowing a little bit out the opening every time i drive it.
e
ed hess
race or get outta the way
erue
only thought i have at the moment is:
is there any kind of baffle immediatly opposite the opening on the inside of the cover? I would think there should be.
ed
jwaller
Evil Genius/SyTy Guru
e
vac pumps kick ass. street use rocks. they keep the whole works clean. elec pumps can be had for ~250 and can put the case under ~13" of vac for a nice 30-40hp...
TyMeUp
To check for excess blowby:
1) Disconnect vacuum hose to PCV valve and plug
2) Take oil fill cap off.
3) Start warmed up engine
4) Have an assistant power-brake the engine to about 1000 RPM.
5) look for excessive smoke or pulsing smoke from oil fill opening.
(for baseline knowledge, do this test on any low mileage vehicle so you know what good/bad results look like.)
Other things to check:
vacuum lines
...(make sure the main PCV hose doesn't collapse under vacuum)
bad (cracked, hardened) PCV line fittings & elbows.
...(If these do not seal, the PCV valve gets reduced vacuum)
bad valve cover grommet
Also, any bad gasket or seal on the engine will leak air into the crankcase. This can disrupt normal PCV circulation and allow oil to flow past baffles and into the PCV valve/system.
ed hess
pump gets you 30-40hp!!!!!! i gotta do this.
wheres the link to the pic erue mentioned above?
ed
GEN3Typhoon
I think this has all been discussed before.. John can you post a link to one of these pumps. I have been interested in this since my truck was diplaying the same issue with oil mist. It is since gone.. but the vacuum pump idea was something we have all discussed before I am pretty sure.
ed hess
yeah
I would like to see how it is installed in our trucks.
theres just somethihng about building a new clean motor and then allowing oil to enter the intake that bugs me.
ed
E-Rue
heres some pics, although i really know nothing about the system.
e
ed hess
Great!
any idea on that pump. who makes it etc. the rest is just wiring, AN, and ss lines.
looks like my next mod..
ed
GEN3Typhoon
Are you sure that is a vacuum pump system... from what I remember the weavers were just using a catch can and those hoses are just plumbed into the catch can.
jwaller
the system on hoovers truck is not a vac pump system but it's plumbed exactly like what you need for one.
just substitue a pump for his catch can and put the catch can on the exhaust for the pump.
ed hess
john
so option 1 is use the exhaust to suck ...creating a suedo vac pump.
and option 2 is the electric vac pump.
but who makes the electric vac pump?
I think that might be a vac pump in the pic. if you enlarge it, looks like something plugs in on the lower left of that thing.
ed
GEN3Typhoon
I saw the pump you are talking about on Summit's web site they were like 249 bucks. Pretty interesting.. maybe something I do at a later date.. right now the evacuation kit I have it doing its job.
ed hess
nick
who made the pump.
Only electric vac pump i found on summit was from a brake manufacturer.
ed
GEN3Typhoon
SSB-28146 Electric Vacuum Pump Kit, Up To 20 in.Hg, 12V, Relay, Hardware, Mount, Hose $249.95
That is the one that I found that I ASSumed John was talking about.
ed hess
yeah i think thats the one i saw. I will have to call them to see how compatible it is when sucking oil fumes?
hopefully its designed for that.
ed
