Got my wastegate figured out
Sy-1177
Turbo Inside
Thanks for all that helped me getting my external wastegate problem figured out. Problem was that I was getting slow spool and only 10psi max of boost. I completely removed the stock gate and wired the lever shut on the exaust housing but under pressure the wire came loose and was bleeding through. So I had a buddy put a bead of weld on it to make sure it stayed shut and now its awesome! Spool up is incredible and is rock solid through the entire run. Can't wait to get it to the track now and I should be able to get that 12sec. timeslip! :D
Sy#26
Was having similar problems myself - found that the "wired-shut" wastegate was a poor fit to the hole (Chan modded 1.4" flapper, 14cm turbine) and leaked like a seive. Drilled & tapped the access hole 5/16 x 18 & welded on an additional nut - now, a bolt jammed tight against the flapper valve seats it completely. Might want to check that.
