got some readings from datastram today
boostedSW
#1691
so i got my hands on a scanner, an got some readings to share with my fellow syty lovers. im a semi noob to the turbo'd world, so go easy.
knock was between 2-4 under idle, WOT - 4 max
air/fuel ratio was between 14.7 idle, the 13.0 under WOT
i seen in another post of what the ty's are supposed to run, am i correct by saying these are decent results for a bone stock ty?
i appreciate any comments.
bezerk
Re: got some readings from datastram today
if knock is 0-4 idle or any knock, you got something not good. the knock sensor shouldn't be picking up anything.
bezerk
also, how you read WB02 readings? was it patched with a wb02 sensor?
boostedSW
#1691
i had read in another thread that 1-3 knock is normal for the sy/ty's. guess i miss understood or something, but otherwise im not sure what your talking about? wb02?
bezerk
you say your a2f ratio is 14.7 at idle...pretty lean for a syty engine.. how do you read this?? some kind of a2f gauge? is it Narrowban or Wideband?
also your engine shouldn't be knocking at idle
codename Bil Doe
Need more info. What wideband O2 are you using? Is it self-calibrating or does it require an air calibration procedure?
Knock is not normal for any engine, much less @ stock. Correct me if I'm wrong (I normally tune na motors but have studied a lot on FI engines), but 13.0 @ WOT for an FI motor is very lean.
syclone rider
Get a Plx wideband no calibrating ever i know the innovative does not sure about the others.
boostedSW
#1691
I had gotten all the readings from on obd1 scanner its a matco scanner, an I was in the datastream. I now have an engine light on, code # 43 something about electric spark. I had also noticed that under steady throttle, the boost builds up quick then drops back to 5psi. Than sometime under steady throttle it goes up then back down an up again
