Got spark and fuel. No start...
skipztt
boost
Ok I got spark and fuel. The truck cranks but won't fire up. I unhooked number 1 wire and put a plug in it and can clearly see spark. I got fuel in the rails. I hit the valve on the rail and fuel comes out.
Possible ignition module?? It's like brand new WTF lol.
Any ideas?
KBowman
Re: Got spark and fuel. No start...
Have someone spray some carb cleaner in the intake while cranking it and see if it will start. Just because it has fuel in the rails does not meen it is pulsing the injectors. If it does start then I would try another ign module or check that it has enough fuel pressure.
The Bronze
Spark that occurs in the cylinders (fouled plugs don't spark, they just go to ground), PROPER fuel pressure (burping the rail is a non-test) and ensure the vehicle isn't in clear flood mode (TPS near WOT) is what I would check first.
Also indicate whether the engine is turning over at a normal speed/sound.
skipztt
boost
It cranks over fine. Just won't fire. How do I check flood mode?
Quickstop [UK]
Combating adversyty.
What have you changed?
Ign wires?
Coil connected?
Valve adjustment?
You got compression?
ECM light comes on?
skipztt
boost
Gonna be getting a gauge on the rail real quick here. What should I set fp at? 50 with vac line off?
I guess I should add that the truck died whe I wad driving it. It started hesitating and wanting to die. I had the feather the throttle to keep it running. But eventually died.
skipztt
boost
It has a stock pump in it. Walboros suck lol. Only thing ive done to it was put the ign module in it last year. Then truck took a dump and it's been sitting since.
Quickstop [UK]
Why do walbros suck?
Check your FP but it might be your fuel pump. Have you got the ECM light lighting up when you turn the key before you try and crank it?
Checked your fuses?
fauXGT
Brick Pilot
Sounds a bit like the trouble I had.
Had fuel, but not enough pressure.
Turned out to be a split in the soft line between the pump and the hard line in the tank.
The OBD said 'lean'.
Any error codes?
