MotorMouth
We'll, I have a mess!! The motor spun the first, second and third main bearings. Havent been able to take the rear cap off but the result is probably the same. There is some pretty deep groves in both the crank and looks like in the block also (havent got the crank out yet).There was about 100+ small to large pieces of bearing all over the motor, from the oil pan up to the lifter bores (wich are damaged also). I have not taken the rod caps off yet but I don't believe thee is damage there. Buy the looks of it, I don't think either the block or crank are salvageable.
Well, I guess that is what you get when the motor is run to damn near 30 psi on stock internals. It is strange though that the heads, pistons,cylinder bores and rods (from the loks of them, havent got them out yet) were not damaged at all. The bores still have he cross hatching and the tops of the pistons look almost new.
Wich makes me wonder.........if the motor is the stocker, I don't think it is.
The valve cover on the passanger side has a sticker that says: NEW GM 4.3.
I wonder if this is one of thoes GM motors with the mix match of parts in them. Is there really anything that sets them appart? It is kind of a mute point at this stage but it would be nice to know.
Anyway, I guess I have a good anchor for the boat.... :roll:
Brian
Brian
