Governor discontinued
jwaller
Evil Genius/SyTy Guru
The correct governor for our 700's has been discontinued. GM, AC Delco and vintage parts do not have them. so if you have one hang onto it.
Re: Correct SYTY Governor Discontinued.
Gota part # so I can do some scrounging just to have one? Just in case as-it-were.
jwaller
I dont have it handy I just call my guys and the dealer and tell them what I want and they get it for me. I can call tomorrow and get it if you need it.
Only if it’s convenient. Just thought it might be an interesting idea to slowly collect some of the hard to find and discontinued parts for out trucks.
Merk
John-
PM me the part number..I'll have a look
Loeryder
from sytyauthority.net
Governor:
OLD: GM #8679638
NEW GM #24202127
Which part# is discontinued? It looks like it was updated at one point.
SeattleSy#1255
Category 5 Conservative
more reason to move on to a different tranny ;)
Loeryder said:
NEW GM #24202127
This number is still valid through GM partsdirect. They aren't always up to date on discontinued part but usually within a month or so...
SEL777
One of 101
CKEITH said:
I Know Where Three Of These Are If Anyones Interested....
If So Let Me Know.
Dibs on one depending on $. Please PM me the $ information. TIA.
Same here.
Thanx,
Don
George Blake
DONATING MEMBER
Just some FYI for you guys before you send your transmissions out for "swapping".
The syty governor #24202127 has been discontinued and there are no stocks left. Like your valvebody, don't let a shop take your governor and swap in an "off the shelf transmission." Use someone on here to have it done or someone you trust to do it right.
Take care.
Loeryder
Re: Governor discontinued
I better grab up an extra considering we still haven't figured out why my trans is shifting so high.
Maybe putting a 100% known stock gov in it will solve my problem.
Looking around there is very little info on changing weights and springs in the gov to lower the shift points.
George Blake
DONATING MEMBER
Yours has higher pressures in it. Makes it shift a little higher. A little more weight will bring down the 1-2 if you feel it's too high.
Loeryder
Yeah I need to do something.
Hitting the rev limiter would be considered too high, right? :lol:
I have all my part throttle shift points written down at home, but every shift was higher across the board.
bdydrpds10
Yes I drive a Typhoon.
Yes, I need to get a stock governor or add/subtract weights on mine.
I keep bouncing off my rev limiter:rant: b/c the stupid person I bought my truck
from swapped out the original tranny with a junk one just to sell it.
JustBeachin
Plays well with others
Jas',
Let me know if you find one, where, and how much, pm or email, so I can consider putting one on the shelf too.
Thanks,
Doug
Loeryder
I have 3 trannies laying around so I could yank one out of another trans, just wanted a brand spankin new one I know hasn't been "tampered" with.
tnsyty
Same here. I have tried 2 stock govenors. No luck. I am going to go with an adjustable one... or a cam so i can get some use for the 5300 rpm shifts.
George Blake
DONATING MEMBER
When going to higher pressures, it ups the TV pressure in the system. Governor pressure must overcome TV pressure to allow the shift. You can put all the stock governors in a trans with an elevated pressure and it won't make a difference. The governor will have to be tweaked to get the shift points where you want them. Higher pressures are used to prevent slip. There are clutches available now that prevent the need for the higher pressures though
Please read this article. If you are in a position that you cannot get a syty governor, you can still get your shifts where you want them.
Governor How to
