Re: GP on SYTY Sway bars
nello said:
Since their was a big GP on Sway bars I'd like to get an understanding about the install before it gets to my door. Reason, I've done quite a few searches and keep coming up with different answers and methods...like jack the truck up, don't jack truck up and put weight in the back instead, drill holes, use existing holes, ect.
Who's got real answers for making this job easy..er?
Safety first. Jackstands are a must or some ramps if your truck isn't to low.
On the front bar you can jack up the front to mount large bushings to the frame brackets.
Then lower truck down, lift bar to control arms and install the control arm bushings & mounts. If you don't lower it, it is very difficult to get the holes in the control arms and the control arm brackets to line up.
For the rear, there are holes in the frame for the endlink bolts.
Mount the bar on the axle so that the bushings are on the bottom of the axle. The directions provide specifics about bushing location on the bar. Tighten U-bolts so that they are snug but not tight yet. You'll need them to rotate a little to get the holes in the end of the bar to lineup with the frame holes. Rotate/lift the front of the bar up towards the frame. There you will see the hole in the frame for the endlink on each side.
Note: On mine I had to remove the gas tank cover so that the bar would clear without hitting anything.
