Great way Determining Real or False KR
Hey guys,
Came across a great Idea to test for real or false knock. If you have any speculation that your truck is false knocking disconnect the KS. If knock is still present, you now know that the knock is cause by EMI. In my situation, my truck would register KR up to 11degrees in park with the truck reved up to 2500RPM. This test also tells you that the knock is not caused by any mecanical noise(rattling, something loose, ect), its electrical. If you have no knock retard showibg at idle, Go for a drive under LIGHT THROTTLE, and see if the knock shows any more. When you disconnect the KS leave the wire hanging in the same area where it was located. I found this really worked well and wanted to pass it on. Now my question, I got 11degrees of KR at 2500RPM, What the hell is causing it????? Replaced altenator, replaced MSD coil with stock, and no change. Wires are new and plugs are new. Wrapped the KS wire completely from sensor to ECM in reflective tape. No change. Any advive....Thanks FERN SY #477
Wes
If you disconnect the knock sensor, there's no way to tell if your truck is knocking. The best way to determine false knock is to put in some race gas and see if you still get knock retard.
leroy
Reflective tape is not the same as shielded wire. You might try that. Also consider a different memcal.
Good luck.
Jim
BillC
Try replacing the pickup coil inside your distributor. I know it sounds screwy, but somebody posted last week that doing this fixed their false knock. I also just replaced the pickup coil, and it seems to have helped my false knock as well (don't know for sure yet, I was just revving the engine hard. I haven't had a chance to take the truck on a drive -- still have to finish putting it all back together).
E-Rue
putting race gas in your truck does not always eliminate false knock.
for example....if your plugs are fouled, no amount of race gas is gonna eliminate the knock reading.
ed hess
race or get outta the way
so when i went to the track i used sunoco 104. ususally i would get lots of knock on the street with 93. using 104 i only had 0-1 degree of retard at the track.
Now i dont know if this is real knock or false knock, but octane makes the knock go away so i would think we would call this real knock.
This will probaly get out of hand but what is real knock and what is false knock?
ed
0-60N4
Good discussion: Ed, you were experiencing real knock on 93 octane gas caused by detonation (or preignition, another subject). If you had been experiencing false knock, the race gas would not have reduced the KR. There can be other sources of "real knock", other than detonation. Anything that causes enough vibration in the right frequency would be a "knock" that the KS would pick up as detonation. We sometimes refer to these vibrations as false knock. If you are getting KR with the KS disconnected then there is something electrical going on that is not related to detonation or vibration.
myclone
ed
real knock: an engine is actually detonating due to things like low octane, boost too high, high combustion temps, etc. This all happens inside the combustion chamber and is caused by the above along with a few other things.
false knock: the ECM is retarding timing and lowering boost due to the percieved knock signal but in fact the engine itself is not detonating. The false signal can be superimposed on the various sensor wires and ECM power wiring by RFI from the ignition system as well as from a partially malfunctioning alternator. Compromised grounding circuits can cause the same symptoms as RFI or compound a smaller RFI problem into a larger one which can "fool" the ECM into thinking the engine is detonating.
False knock can also be caused but the knock sensor picking up mechanical noises from other sources that are transmitted thruogh the engine block to the sensor. Things such as the DP rattling against the frame, bearings going bad in the accessories(alt, water pump, etc) or any number of things that can make a mechanical noise which is in the right frequency range that the filters pass it along to the ECM as "real" detonation.
Lot more to it but I'll let someone who knows how to splain it better fill us in. :wink:
ed hess
how would you know if you have an alternator that is 'partially' malfunctioning?
ed
Ive already checked the the pickup coil on a scope and the pattern is beautiful. Weather it is emiting EMI I dont know. Buy doing this test it tells you weather the KR is caused by EMI or mechanical(other) source than electrical. Race fuel wont tell you this, and this is a cheaper test than buying race fuel. If this doesnt work, than try the race fuel. I running Magnacore 10mm wires which are advertised to be great EMI and RFI suppressors. Im gonna try stock wires, but, I think I had the stock wires on before with the same problem?? Where can I get shielding ground cable for the KS wire?? Thanks guys Fern Sy#477
smeagol
Not saying the wires are your problems, but in my experience, I've seen nothing but problems with Magnecor's. Between burning up, causing misses etc etc. Just my $0.02
Shielding, look to the electronics stores - Mouser, JDR and what not. Lots of electrical supply places.
Thanks for the info Green,
Im gonna try another set of wires and if that doesnt work Im gonna get sheilded ground wire around the complete KS wire. I let everyone the progress when I find out. Fern Sy#477
myclone
ed
Well, several ways... Since Im a cheap SOB I listen to the stereo with the volume turned all the way down. If I get a "whistle" out of the speakers that has a frequency proportional to the engine RPM then IMO the alternator is "leaky". Its not really RFI its AC thats getting past the rectifier as alternators produce AC then the rectifier converts this to DC that the electrical system needs.
Another way is to have the alternator load tested as the rectifier may be fine in a low current draw situation(no lights/HVAC on, light throttle, etc) but start to break down once the current load goes up(lights on/HVAC on, inj duty cycle is high, etc). This could dump AC into the ECM and poss cause the false knock.
Ive scoped myclones electrical system just for the heck of it and its full of RFI/EMI even with the acc belt off(alt not turning) so IMO anything you can do to get rid of RFI/EMI wont hurt. Making sure the grounds are in tact and functioning is a good start at first.
