Greddy Profec B-Spec II Boost Controller settings
91blazins10
Anyone that has this boost controller can you post your settings right now mine is
set- 60%
gain-19%
set gain 16psi
and I get 20psi about, when I mess around with it sometimes I can get 23psi but its not consistent im trying to get to 24psi consistenly.
ViciousV6
400HP/550FTLB
Re: Greddy Profec B-Spec II Boost Controller settings
set- 60%
gain-19%
set gain 16psi
Well Your set is your main % of boost the truck will make.
Gain is to fine tune the control up or down
The set gain is how fast it will spool up to if you want 23 lbs i would advise to bring the set gain up to 20 andif it goes over 23 then bring down the gain to 15 and little more if needed.
What kind of downpipe/wastegate are you using.
mmp142965
say it like you spell it!
i have my gain at 35% (all the way up)
50% and set gain at 13.5
i get consitant 16 psi with this setup with stock down pipe, no cat and ported wastegate housing.
i tried with lower gains and the boost would rise up with RPM. the set gain should be about 85% of the desired boost. too much and it will spike and too little and it wont spool as fast as it could.
TYTILIDIE
METH HEAD
You do know that nothing on the Profec is "PSI" right? Its going to depend on your set up for sure. I have my gain @ 5. Im pretty sure GAIN is how fast you spool. Set gain should be your boost limit so to speak. I cold be wrong.
