GT fuel issues
jjorgensen52
NHSTE - I'm the only one!
GT has been doing this for months now, and I'm stumped. Some days won't start, period. Others it will. Today it started, ran about 2 mins, stalled and would not restart. No injector pulse when it won't start. Good injector, new fuel pump, good relay. Anyone know what could cause this?
supersports10
Re: GT fuel issues
bad pulsator in the tank????
if you jumper the fp test terminal do you get fuel pressure???
if so how much pressure?
have spark???
jjorgensen52
Re: GT fuel issues
have spark???
No pulsator anymore, removed it when I swapped the pump. I have 60 - 62psi FP at the rail if I jumper the pump, and I can hear the pump run when I turn the key
Yep, has spark. Shot of carb cleaner and it fires every time
jjorgensen52
Re: GT fuel issues
Thanks Dave, that solved the problem. As it turned out, in R&Ring the intake I had bent the contact on the connector in such a way that they were only making intermittent contact. Straightened those out, put in some lithium grease and she fired right up. That's when I found the timing was retarded 18* :eek: ... amazingly one can reach the distributor bolt on an L35 with a regular box end :D
Re: GT fuel issues
Glad you got it solved, I was a little slow reading this thread. I had the same issue before.
That pesky dist. bolt...LOL I used to do it by breaking it loose with the boxed end then flipping an open end wrench back and forth until I finally picked up the one bent in 45* to use with ratchet.
