GT35R vs PT61 BB
I was doing a search the other day and I didn't even realize that PTE started doing BB on the smaller turbo's.
http://www.syty.net/forums/showthread.php?t=31599
Previously, I had my mind set on a GT35R, but the new PT61 BB seems very similiar and is priced cheaper. What are he advantage/disadvantages to either? On the trubo buick forums, I found the PT61 uses the GT35R compressor wheel, I assume this is true for the SyTy/BB version. I also know the GT35R need some clearancing work to be used with the AC bracket.
AXXE
Re: GT35R vs PT61 BB
I think even the 61 is going to need clearancing. I have the GT35R and the ball bearing center section is much shorter than a regular. I would think they would be using the same BB center section on all of the turbos. Check with Turbotime. I am sure he will have the correct oil return line and averything. When I installed mine, everyone thought it would fit and it didn't. I ended up making a custom oil return line and cutting the A/C bracket up quite a bit. I don't know how much more power BB adds. I did it because I had a lot of $ at the time and I wanted to see how it would spool up with the stock converter.
jwaller
Evil Genius/SyTy Guru
the only way a bb will add power is by bringing the boost up quicker thus giving more power under the curve, at a given rpm and bost you should have the same power with all things being equal. the bb turbos feel more powerful on the street bc the power comes on sooo much quicker and harder.
VermontTy
Support Our Troops
and how did it spool with the stock converter? Could you expect the same out of the 61BB?
Sy#2373
I love my GT35R.
The spool time is amazing and it pulls hard on the top end.
I ran mine with the stock converter for about 8 months and it was not that bad.
I'll be hitting the track as soon as i get my Prop Shaft safety loop installed.
I just started installing mine this week. Looking at how much clearance the stock turbo has, and then looking at the much larger GT35R, it doesn't look like it is going to be easy.
I am torn about keeping the AC or not. I like having it obviously, but it's hard to work around and the engine bay would look so much better without it.
The 3" GT35R inlets, are supose to fit with some grinding of the A/C bracket. I for one will not sacrifice A/C in my Syclone. For me, a summer vehicle and black interior, A/C is must have. I am not willing to make that sacrifice for performance.
Big Mike
I have the 4 inch GT35R installed with A/C pics at NortheastSyTy.com gallery page 4 under Big Mike pics
Sy#2373
You don't have to remove your AC to use the GT35.
The front corner of the AC bracket has to be cut off, no big deal.
AXXE
Looking back at, it was not worth the extra $ and the cutting for the GT35R. Buy a bigger turbo and a good converter. It will spool up the same, fit better and make more power.
