Happy 1 min...sad the next
Injected1
Last night the truck ran smoothly for the first time. After installing the 63# injectors, new wires, cleaned up plugs and re-gapped to .028. The truck never idled smoother or cleaner than last night. Then this morning I was going to do some tuning, did a little last night added some fuel to the bpc about 25% and it idled for a long time smooth and perfect. I even drove it up to the gas station to fill it with about 15 gal worth premium fuel. Ran great very slow cruising and idling. The gas station is about 2 miles away, never went over 2500 rpm as I was just driving on a base bin.
Fast forward to this morning and I was going to go take it for a 40 mile drive to Karl Stump, one of the top rated forced induction tuners by PTE. I went out prior to us leaving to warm the truck up and check all the fluids. I cranked the truck it idled fine for about 8 min Afr's were for the first somewhat steady and in a reasonable range as they were last night. Then out of nowhere it died. Got in it to crank it up and it wouldn't idle afr's were all over the place. Lean to rich had to hold the throttle at 3% to keep it idling. Tried to drive it and afr's went to to the 9.80 and wouldn't drive at all.
So far i have tried the following:
1. a different bin -- same thing
2. Resetting the Iac---no help
3. Checked all spark wires---nada
4 pulled all cables and g1---nothing
5. swapped ecm's----no diff
6. checked timing---nada
7. shut of battery disconnect, pulled ecm 1 and b-----seemed to help, didn't idle for more than five minutes had to shut it off...ill see if it fixed tom
what could have gone wrong? any idas would be appreciated.
Injected1
Re: Happy 1 min...sad the next
Update just went out and cranked the Sy. Idled alot smoother than earlier today but still not like last night. It was hunting for an idle and fluctuating from 12.5---18.0 on the afr's and everytime it got to 17+ it would hiccup and almost die. I let it idle for 10 min, it never got up past 165 do to the outside temp being about 50 deg. Not sure where to go from here.
Quickstop [UK]
Combating adversyty.
bad fuel maybe? what is your FP/AFPR doing? got a DM of the idle?
Sorry to hear this - these trucks are temperamental or what!
1madgumby
Sounds like you got bad fuel from the station. go drain it all out & go to A different station and put like 1/2 tank in it. Bet that is the problum, O pull the fuel filter to see if the is any water or anything in it. Fuel tank underground at the station could have been at the bottom & sucked some water up off of it. Thats what it sounds like or A bad ground could do it also.
Good luck.
Injected1
http://www.mediafire.com/?twmtyj4wuym
Not sure if I did this right but the truck seemed to idled smooth until I turned on the 3 electric fans at 180 deg. Then the truck died I restarted it, idle was not good and afr's were fluctuating from 12.5--18.0. When it got back down to 160 I shut off the fans and the idle was smooth again with afr's reasonable range. I then turned on the electric fans at 185 it immediately killed the truck, restarted and the same thing happened.
http://www.mediafire.com/file/twmtyj4wuym/Idlelog1.uni
sy2675
He Saved the Pimp'n Game!
i dont remember where, but if you are tuning via code 59 there is a place to add and cut fuel based on battery voltage, basically it would see the voltage drop when the fans are kicking on and bump fuel up to accomodate the need. I had a problem where why fans would kick on and the truck would die, but only when at idle.
Does the truck die if you hold the rpms up and turn the fans on?
bezerk
have you tried disconnectieng the stock o2 sensor so it's in open loop?
sy2675
also there is settings for "hot startup" a fuel map that the ecm uses for a specific amount of time after you start the motor, if you are trying to tune or datalog during this you will have problems. ASK a SYTY CODE59 tuner, like dig or jeff scott for some direction!
and it is winter time, does your gas station have wierd gas mixes for cold weather months? somethings to consider.
Injected1
going to upgrade the alt and I think I have found the section your talking about in tunerpro. Is it F92, how does it work?
sy2675
i'll pull the laptop out of the sy in a little bit and see if i can find it. I had Dig do most of my tuning, so im not the best person to give advice.
I have a really good 60# bin, if you want to try it tho. Different heads and cam than you though.
Injected1
I have 4 starter bins for 65's and I think Quickstop is sending me his which is almost my identical build.
thank you tho.
