Hard Starts
mysyclone
I'm having hard starting issues. i went through the standard stuff. when i turn the key, relay kicks in and pressure is good, and holds for LONG TIME. if you turn the key it cranks hard (fresh battery) but nothing. I use ether to finally get it started. i've checked the standard stuff ( wires, cap, etc.) any thoughts?
MikeRenz
not stock
Re: Hard Starts
sounds a lot like fouled plugs...you said you checked the standard stuff, but didn't mention plugs.
ziembic
Re: Hard Starts
Is this when it is hot or cold or both? If it is only when it is hot, then it sounds like your baking the starter. If it is all the time, it could be a ground issue. Take a set of jumper cables and use one side of them to ground one of the starter bolts to the ground on your battery. If it starts easy, you have to check your grounds and or add one.
Re: Hard Starts
He says it cranks hard which I take to believe it cranks fast. Not a starter issue if that's the case. I'd say check dist. ig module. Plugs? Yes, he didn't mention those. How well does it run once it starts? Pos serious vac leak causing a lean mixture for starting. I'd sure start with the plugs though. Easy first next step.
SYCLONE#1531
'MOFOFAST
Re: Hard Starts
Maybe you need a remote starter solonoid?? :dunno:
mysyclone
Re: Hard Starts
Pretty sure it's not the starter. It turns over fast. i thought plugs and wires as well, so i replaced them (AC Delco Wires, Accel tan cap rotor button). Still the same thing.
It starts right up after engine is at O.T.
As far as running, if i come off the light easy, it runs good. if i come off hard, it spits and sputters, until it gets some momentum. thats a story for another day.
BMFB
Not to scale
Re: Hard Starts
Mine did that right after I rebuilt it due to the timing being off, at least the starting part, I timed it before taking on the road, so i cant be sure if it would have cause the other issue
mysyclone
Re: Hard Starts
That's funny you mentioned the rebuild. Ever since i rebuilt the engine it has done this. i timmed it after i finished it, but i wounder if i installed something wrong, it will not run if it's 180 degrees out though. i might have to investagate that more.
Daron
Re: Hard Starts
If still an issue after checking timing: Check Fuel Pump / fuel supply...
mysyclone
Re: Hard Starts
35 PSI at startup
It's the original pump, so i might replace this summer. I hate dropping fuel tanks.
Re: Hard Starts
I agree. You can actually get away with tilting the bed up on the drivers side. That's the way I did it. Got some pics somewhere, I'll try to dig them up.
ziembic
Re: Hard Starts
is it just me or did anyone else come in here thinking that Robert was having hard start problems? For some reason, every time I look at this post I think it says mrsyclone. I am thinking, the guy runs high 8's and can't get the thing to start...lol. I knew it couldn't be true.
powercat6
Re: Hard Starts
I thought the same thing.
