have questions on int & blm
Gnocide
turbo game burt reynolds
when on cruise control at about 75 to 80 the blm and int are both 118(subtracting fuel).
which is within + or - 10 of 128(no adjustment)like the scan master book says it can be.
should it be 128 or closer all the time ?or is this normal for highway trips?
wb says 14.9 - 16.1 & fuel pressure is at 47 line off additionally.
thanks
Gnocide
Re: have questions on int & blm
Why is your fuel pressure so high?
10% increase in a/f ratio- which was needed to run 22psi on factory injectors ,no alky or race gas ,safely.
but now i have 42.5 lbs injectors so i may not need the 10% anymore.
anyway..
what is everyone's int and blm going down the highway///???
Gnocide
crickets
anyone have a scanmaster or other scan tool computer to check yours?
bundie
22psi on stock injectors with that turbo???? My truck is bone stock with ttchip and om running lean with stock injectors 15psi 100%duty cycle on injector.
I still need to try out raising feul pressure
Eric Sy GN
It's not a big deal as long as it's running ok. Are you using the stock O2 sensor, or simulated from the PLX? The higher fuel pressure may be driving the BLM and INT down.
Gnocide
truck runs fine
no o2 sensor just plx in its place instead.
with code 59 i used 50 psi and ran great so just coming down a little with bigger injectors.
Gnocide
turbonetics 60-1 stage 3 turbo.
my stock inj were beyond 100% duty cycle(off the charts) at 18psi and of course leaning out at 43psi fuel pressure @ around 13.5 on the wideband.
so up to 50psi nets a bigger a/f ratio(10% over stock) which allows running the same boost in the 11.5-12.5 wb range(safer)
THERE IS A LOT of extra that allowed me 22psi.
here they are in no particular order:none of them include race gas or alky.
1) 7th injector -got my duty cycle to about 85% and allowed more boost on stock injectors.
2) atr external waste gate (ported)- not electronic- always set exactly where you left it-never moves- ever
3) ported compressor turbo hole- most often overlooked- solid efficiency boost control
4) atr big capacity liquid inter cooler- more efficiency +more boost
5) aux charge cooler with fans-double capacity = more boost less knock
6) a great code 59 tune for safety and reliability.
7) more fuel pressure -cant make hp without fuel
It's just a six
Super Member
Gnocide;10214571) 2) atr external waste gate (ported)- not electronic- always set exactly where you left it-never moves- ever l[/QUOTE said:
Do you ever go to different tracks w/different altitudes?
Might want to run an electronic boost controller, it will allow for faster boost response, quicker spool-up.
Just a thought.
12:5 A/F ratio is not really on the safe side.:2cents: But, hey every truck/engine is different.
Gnocide
Just a thought.
Electronic does a nice job- have one on my Buick. - not necessary with my particular convertor/ turbo combo , typhoon spools like a mother.
I dont really go to many tracks but boost is only an allen wrench away from adjustment if needed at all.
Correct -12.5 isn't safe at all- hence the code 59 Aeroking tune put me at 11.
but as you can gauge, higher f/p it did provide a better a/f margin- it brought it into the 11.5 - 12.5 range
where as leaving at 43 would not have and i would have had to turn the boost down.
the down side is that its still 50psi when your not wot.
Eric Sy GN
If you want it richer at full boost, you can add WOT fuel using the chip adjustments. No need to increase fuel pressure (unless you're at 100% dc).
On the BLM/INT, if you are using the PLX's simulated output connected to the stock O2 wiring, then I might need to make an adjustment in the chip. I've seen sometimes where the simulation drives the BLM's down even when it's not rich.
Gnocide
i can and will now + i have bigger inj .
under stock inj- i was beyond 100dc
pretty sure this is how its done- my a/f under wot is good so far and driveability seems fine
+i want to drive it before i send you the chip back ,its really nice for a change.
