having a problem with 29c256 and pocket programmer and tuner cat
turbotater
i tried using a 29c256 chip to do some tuning with
and i keep getting an error
definition file not compatible $58 should be used .
i have $58 already opened in tuner cat .
i have been told to start my burn at 4000 and
end at 7FFF because of the 128k image file .
i have tried using the program the truck is running on now
and still get the same error . if i install it in the truck
it turns the check engine light on and runs like poopoo .
any ideas
Re: having a problem with 29c256 and pocket programmer and tuner cat
try filling the buffer with ffffff first and burn it like that and then check to make sure it can be reprogrammed then load your file in the buffer and burn the chip. See if that helps. Device start is 04000 and make sure programmer is set for the 29c256
________
AVANDIA LAW
leroy
I'm not sure this is your problem, but Tunercat expects the program ID at 0x0008 to match the definition file. A lot of folks enter AA instead of 58 to disable the checksum.
HTH,
Jim
turbotater
syclone 0209 : tried that no luck , it does say it is
blank after that when i do a blank check and it say
that it is programable .
leroy : where are you talking about entering AA ,
somewhere in the pocket programmer or in tuner cat ?
what i am most confused by is the fact i can load my
'730 8d code for my firebird and burn it and it works fine
and tunercat accepts it but not my typhoon stuff
thanxs for the replys keep em coming
leroy
If you have your definition file setup to edit the program ID, tunercat will work. It's listed in Promgrammer. You could also just use a hex editor. I believe the pocket programmer has a hex editor built in. Go to 0x0008 in the editor and see what is entered. If it's anything other than 58, you will get the error message. If you want you can send me your bin, or your tdf file and I will take a look.
Jim
turbotater
i opened the edit buffer and in the top row verticle column
it has 000000 for an address and i looked at the 9th horizontal
character ( which should be correct including the zero )
and it had a 58 .
on pocket programmer there is a box for choosing what looks like
the format for values with the choices being Bianary, Intel Hex ,
Motorola Hex , Ascii Hex . It is defaulting to Bianary , is this correct ?
Leroy: i will send a copy of my file as soon as i can borrow a pc
that has a 3.5 and a cd burner (my lap only has 3.5, my pc only cd's )
as my lap is not internet connected right now
thanxs
leroy
and it had a 58 .
thanxs
Binary is correct. I think you have another problem. Tunercat should let you edit anyway even if the program ID's don't match.
Make sure the buffer starts at 0000 and the device starts at 4000.
After you burn the chip, try reading the chip. Make sure it matches the original binary. If it doesn't, you have a problem with the programmer, or programming steps.
HTH,
Jim
