Having trouble after installing speedpro
BigAl...
As some of you know I installed speedpro on my truck last week(Big thanks to Nolan), idle, off idle and drivability are just plain awsome. Well I'm having trouble diagnosing a really bad stumble. If I slowly take the revs up to 2200-2500rpm and then step on it, it feels like I hit a rev limiter, BUT if I slowly raise them to over 3000rpm and then step on it, it runs like a raped ape but when it shifts it does it again. I've changed the cap/rotor, ignition module, tightened the gap to .025. Plugs look great. this is driving me nuts. I really feel like it's a hardware problem not a calibration problem. The a/f ratio's are around low 11's when this is happening. any suggestions would be greatly appreciated
TIA
BigAl...
What injectors/combo? Send me the program and I'll try it out. If it does it for me then it's probably a software deal. I can send you a program to try if your combo is close.
BigAl...
With help from Nolan and Harry(PTE) the truck is now running awsome. It turns out the problem was all ignition related, after changing the cap, rotor, ign module, distributor, coil and plug wires the truck now runs awsome. I think in the end it was a combonation of p/u coil and ign wires.
For those of you that are in need of tuning beit stock ECM or FAST, you'd be crazy not to call Nolan, he spent alot of time on the phone with me trying to figure out my syty wo's. This guy really really has the knowledge to get these finicky trucks running fast. Big thanks to the Canadian contingency!
BigAl...
Pittman
I just bought speedpro with some 83# injectors. installing it all next week. Where did you put the computer? Was the install a bitch? Any words of advice??
GEN3Typhoon
Mine is in the glove box... installation was not that bad
If you did not buy the adapter harness... I would suggest doing so.. saved a lot of headache as far as I can tell.
If you did.. I would go ahead and add the wires to the harness for the fan and the Nitrous controls... unless you don't plan on using them.
Other than that... it is pretty straight forward, just time consuming.
I spent more time hiding and routing wires than anything.
Hope that helps.. if you send my your email address I will send you the complete wiring diagram and some starter programs.
Mine is nick.steffens@usionline.net
Pittman
Yeah Ive got the harness and already pulled the temp sensor I had in the head for the fans. oh man I dont want to loose my glove box. What inj did you guys go with. I went 83 lb. Ive got speed pro for the buick too. however its still it box. That car wont be out of the chassis shop tel march
GEN3Typhoon
I am using the 83# injectors also... got a good deal on them.
Harry tole me that would fit in the stock ecu location.. well it will physically mount there... I made a nice bracket for it using the stock bracket... but all those wires from the adapter harness will not fit up under the dash.. I tried for several hours to make them all fit with no luck. There is still room for the owners manual, etc in glove box. I keep those tucked away out of the vehicle anyway.
Also I don't daily drive mine so I am not too worried about it... I just toss whatever I am taking with me in the back seat.
Later
Pittman
Mine is not a daily driver by any sense of the word. Neah Im just a clean freak. Dont like anything in the open. If I totally remove the glove box I guess I would have easy access to the computer and ample room for wiring
FLSY2730
Later
I used the stock bracket and tucked it back up in the stock location and even used the stock screws and holes to hold it up, the wires were a bitch to get all up there but i got it . :D
GEN3Typhoon
Well.. since mine is already in the glove box.. it will not be much effort to try to move it again.
Since you made your fit.. I am sure it will be worth a second shot... of course if you can't see it.. the better off as far as clean install goes.
Thanks.. I will try it again.
I cannot have yours looking better than mine.... 8)
