head gasket parts
Big Mike
Re: head gasket parts
You may want to replace/up grade the head bolts and thermostat too. you will also need upper to lower intake gaskets, throttle body gasket, distributor gasket, intake to head gaskets (make sure you use the right ones Victor Reinz brand or orig GM, same with head gaskets or go cometic but with cometic you need a certain finish done to the block and heads). as far as i know felpro does not list head or intake gaskets for our trucks. Turbo Z motor. our motors did not have exhaust manifold gaskets from factory, you may need an exhaust spreader to re assemble manifold to head. Have fun good luck been there done that. Any questions Pm me i am about 45 minutes from Dover. you will also need a power steering pump pulley remove/install tool.
Quickstop [UK]
Combating adversyty.
Dowel pins
RTV moly lube/thread sealer/locker
lots of RTV silicone for the lower intake
what heads are you putting on? - vortecs are a different experience as well as there are coolant passages to be plugged.
Exhaust manifolds didn't have gaskets factory but some on here use the MLS gaskets that are now available, including me.
