headers
headers
  • yes
    Votes: 8 66.7%
  • no
    Votes: 4 33.3%
  • Total voters
    12
  • Poll closed .
cloneman315
what do u guys think i am not convinced one way or another,do i put headers on my new build or run the stockers,im wondering if with the bigger motor, heads ,turbo they will work better than a stock motor as far as making more power goes,or should i save the 1000 bucks and use it someplace else,im just not sure if the comon problems burnt wires, leaks, cracking etc are gonna be worth the power i might gain by using them .
DynaGlide
Ton-Eighty
Re: headers
As long as you are running heads with straight plug angles, use the stock manifolds. In my opinion, the headers aren't worth the headache if you can just use existing manifolds. We don't have enough room under our hoods to make tuned headers anyway. Just my 1/50th of a dollar.
blk00z28
Forced to by choice
Re: headers
Spin off question of his;
Are you still going to be running AC and ABS? If your not, then you will have more room under the hood to not worry about tight spaces. I've already told myself, if and when (depending on who's headers and how much I wanna spend I guess.) I do get headers, I'm having a welding friend of mine beef up the welds on them just incase. That way I dont have to pull them back off a few months later. ;)
