Headlights not working after theft attempt
Hello, first of all thanks in advanced! Someone tried to steal my 93 Typhoon and they did a whole bunch of damage. After they were unable to steal it they pretty much cut every wire under the dash and the ones in the column. I've since pretty much repaired everything with a couple of exceptions. Yes, the bastards who tried to steal it, also popped the hood, cut all the wires to my ATR 7th Injector, and the on/off switch for my ABS brakes. I've repaired almost all of the wiring issues, except my headlights won't turn on now. I removed the switch and found that on the connector that goes to the switch, the far right cable, a dark blue one, is cut. Not sure where it goes. There is no obvious location to where that wire was cut from. My dash lights and head lights don't turn on. All other lights work. If anyone can provide some help, I'd greatly appreciate it.
Damian
Re: Headlights not working after theft attempt
I'm not good with electrical stuff but damn on the attempted theft. My Jeep was stolen, I'm so glad they didn't cut everything like they did yours. Just keep it parked in a garage if possible.
Thanks Damian unfortunately, old house in the bay area with no garage.... Whoever tried to steal it cut all that wiring just to be malicious. They didn't get it though, thats the important part. Sux about your jeep though. Nothing makes you feel more violated than when someone takes something you've worked for.
Logan
While I cannot help with the lights I do offer services for situations like this, I have a side business called "Kneecaps by Tonya Harding." We are fully licensed in all 50 states and employ homeless people so you can rest assured that the recipient of your Harding-gram will not only appreciate the care and effort of our passion for professionalism but it is also for a good cause.
93Typhoon08ZX6R LOL that just made my day. Wish I could find who ever it was that tried to steal it, have a mortician in the family..... Although I like the idea of giving back to the community by employing the homeless.
berzerker
wookie
check all the wiring at the ignition switch , something got pulled off there . and by ignition switch i mean the switch at the bottom of the column .
DaveP
This post is actually on-topic. So for the rest of you don't bother to read it. This one is actually trying to help the OP with his problem.
Interesting. I know there's no "dark blue" wire anywhere in the vicinity of the headlight switch on a stock S-series, so I had to investigate further.
I went and looked at a dash harness I have in my stash. The connector has 6 cavities, but only 4 wires. The headlight switch has 6 connections. So 2 are unused in a stock configuration. Someone has added something (the blue wire). I have no idea what.
Check the dimmer switch on the left side of the column. Has a yellow, tan and lt green wire in a 3-pin connector. yellow should be hot with headlights on. Same yellow wire as at the light switch.
