Re: heads warped
As far as getting push rods might want to wait till heads are on truck so you can measure for them, springs need to be matched for the cam you are going to use if it is a 412 and you have no cam card you can look up the specs on comp cam web site, locks and retainers need to match the spring size you are going to get for your cam, rockers need to be self aligning weather they are 1.5 or 1.6, you are going to need Arp studs for Vortec heads along with hardened washers to raise stud up so you have enough threads for the rocker nut if you go full roller rockers, the stock valve covers can be re used, I am sure there is a machine shop that can drill the heads and get the parts needed and set them up located in Dover but if not there is a machine shop that I have used in New Castle that can do it, they can get what ever is needed also let me know if you need the number for them. If you do buy those other Vortec heads you may need to get them checked out and do work on them to get them right for you combo. If you spend the money on yours you know what you have.
