Heat not working
SEL777
One of 101
Ok the heat is not working. Here's what happened, start truck this morning and heat is on high. Turn it down as it is cold and hit it on the way to work and no fan motor noise. This has happend before and I had it repaired at a dealership. They replaced the relay, and motor then, it then did not work the next day. I took it back to the stealership and they cleaned the contacts on the HVAC selector and volia it works. That was 2 years ago. This time one thing is different, when I turned the HVAC system OFF is notice a much louder vac noise hiss behind the selector. THIS IS A NEW NOISE! We recently changed the stock vac lines (under the hood with the Neoprene vac line kit) but, it has been working fine for over three weeks. We expect a foot of snow starting tonight and I need heat or I can't drive. I will see what happens tonight when I leave work but, I think I may be w/o heat. Any ideas on what to look for when I pull out the HVAC controler?
Flyin Ryan
hated cuz he drives fords
Re: Heat not working
Don't know if this is of any help
also about the hissing noise it's pretty common issue with s trucks
http://www.syty.net/forums/showpost.php?p=539893&postcount=8
SEL777
One of 101
Cool thanks. Does anyone know the part number for the diaphram listed in the thread link above?
