Re: heater core as aux CHE
turbodog said:
Hey, Daron... a while back didn't you and Blake devise an auxiliary CCHE from Ford heater cores? If so, do you still have any info on that you could forward to me? Thanks!
Years ago... I went into AutoZone and told the dude at the parts counter I was building a project. He let me browse their Heater core stock and I picked up the largest one they had, that had 3/4 inlet/outlets. This worked pretty good, especially at the track since I would run the pump and spray ice water on the heater core while in the staging lanes.
I removed it some time ago to go to a motorcycle radiator with a built in fan, but the deal fell thru. I then put the system back together without an Aux CCHE, since I thought I was going a different route later. Turns out it worked so well with a Jabsco, CCHE scoop, hose mods etc that I never bothered with the aux cche again.
Now that I am running alky I have more than enough Intake temp drop.
If I were to go at it again I would just pop a nice pair of fans on the stock CCHE, upgrade the pump and route the hoses in a manner that doesnt include the use of 90 degree bends.
