Heater Core Hose Connections?
NOWAY55
I am in need of some help. I just picked this thing up and was told it needs a heater core. Well, I replaced the core and still don't have heat. So I look around and what I think is that I must have connected the hoses to the wrong place under the hood. Can someone please verify where the feed is and where the return goes for the heater core. I think the return goes directly to the radiator. This is bad because the person who had the truck before JB welded the nipple closed and it looks like I will be buying a new one. The feed to the core is where I need some help. This thing also has an Air - Air IC on it and the stock liquid has been axed. So I don't know where those hoses are either or if they have been plugged off. I suspect I have connected into one of them?
Thanks.
Black Knight
I Glow Therefore I am
Re: Heater Core Hose Connections?
If you don't have a A2W anymore then you couldn't have hooked into, because to go A2A you have to remove all the original I/C parts. I believe the heater hoses are routed from the intake manifold to the hose on the drivers side of the 2 hookups for the heater core and then the radiator to the hose on the passenger side of the heater core.
NOWAY55
Would that be the small neck on the top of the intake manifold? If you are looking at it from the front of the truck it's to the far front left of the intake. It's a smaller size maybe 1.5" or so.
Thanks!
Black Knight
Thanks!
Yep :tup:
Black Knight
Should be closer in size to 3/4 not 1 1/2
I went and looked and it can be a little confusing, so also the one one on the bottom of the heater core to the manifold and the one on top to the radiator. Either way.
