heater core problem fixed
s_blazin
i bought a brand new GM heater core for my s10 project. the truck never had AC and i'm adding it. so i had to take all the heater core and vent system back out (it was already in) to get the AC heater box on the firewall to be able to get over the heater core tubes and also the inner heater box stud was making it difficult.
the truck has a v8 in it currenlty so room issues are worse but where we positioned the motor seemd to be a good place, i have enough heater box on firewall to valve cover clearance but as i put all the inside stuff back inside and went back under the hood to finish tightening the heater box to the firewall i saw this...... the heater box is pushing HARD on the heater core tubes.
i also had an issue with the hole closest to the valve cover where the stud goes through, that one hole wouldn't line up.
also the bracket that screws to the heater box to hold the tubes won't even fit the tubes.
now that i think about it i wonder if that has something to do with it?
anyone ever have this happen?
Re: i get screwed every time heater core not fitting
Well IMHO it depends on what you mean by "pushing hard." When I did my heater core I did have to bend the tubes slightly to get everything to lineup.
kentuc
I think A/C and nonA/C heater cores are different.
s_blazin
i was afraid of cracking or squishing the tubes but i guess i can try it
i bought an ac heater core
SY2932
Administrator
They are. The heater core for a truck with AC has longer stubs on it than a non AC one because of the additional depth of the AC blower box. The stubs are shorter on a non AC heater core since the blower box isn't as deep.
With regards to the lines, did you try to prebend them to match the angle of the old heater core before you installed it? That's what I had to do on mine when I replaced it a few years ago. Even doing that, it was still a PITA.
s_blazin
no i'm going to go do that now, everything on these trucks is a PITA
s_blazin
alright gentlemen, i was a bit nervous to try bending the lines, should have thought about it but i guess you don't think well when tired.
anyway got it all straightened out
this is the new fit. thanks guys for the tips
original one on the right new one on the left. no wonder it didn't fit, i never thought to compare them before the install
