Heater Hose vs. Stainless lines
Vaders Sy
I am going to be rerouting the IC lines here soon. What advantages are their for using a stainless braided lines other than cosmetic over a regular heater hose? Will the 3/4 quarter hose still work on my ATR intercooler? ATR did tell me that the fittings on their intercooler were 5/8 and 3/8. I know very little about fittings and such. Stainless braided or heater hose?
myclone
Heater hose will be more than adequate and not to mention is much easier/cheaper to work with. SS braided hose is not needed IMO unless youre going for some extra "bling".
Vaders Sy
Which size hose will fit my ATR intercooler? ATR told me it was a 5/8 by 3/8 fitting. 3/4 still work or not?
Thanks for the info.
TurboTony
When we did the build on Carmens Ty we reused his ATR upper.
I made some fittings that were a 3/8 pipe thread with a 10an male end. Basicly we bought four fittings and cut them in half and welded the ends we needed back together.
You can buy such a fitting but they were spendy and a few weeks away at the time.
The other option was to use a bunch of adapter and such, that would have been ugly and space is a bit of a premium with the ATR upper.
We used some 10 an puch in elbows to the 3/4 inch heater hose and they fit like a glove, looked sporty and made it really easy to work with in the future.
Steel braided hose is a PITA and the fittings are expensive in the correct sizes. Not to mention it's ability to chaffe anything it rubs on and stab your hands everytime you touch it.
There may be picks on the website, not sure.
Tony
GM TURBO
Sell Out
Call me crazy...
With stainless hoses - do they do any time of insulating from heat? My thoughts say it is going to retain heat longer then a standard hose.
Vaders Sy
Turbo Tony
Turbo Tony
I don't have the ability to weld and make my own fittings. You said you used a 10 AN fitting/elbows then went to the 3/4 heater hose? Sound right or did I miss read your post? I would need four right? 2 for the intercooler and 2 for the CAC.
As for the stainless steel lines retaining heat, I have been wondering about that myself.
gkrcr882
SyTyless......for now!
In your case I would go with the plain hoses. while stainless (or any metal excpt cast iron) transmits heat realtively quickly, it also dissapates it quite quick. Stainless does have its downs though: sharp protrusions from braided, needs to be TIG welded (better start practicing) and its $$$. if you were doing a brake system I would use only stainless because it dosent flex and its not as hard to clog with crud as rubber. but the problem is that most people are used to doing a double 45 flair, when you have to do a single 37 (i think) otherwise if you try to do a double on stainless it will split. back to the topic, for somthing like an IC hose, i would use the plain stuff, but if you are going for eye appeal Mr. Gasket makes some flexible radiator hose that comes in different colors like blue, stainless, purple, yellow, red and pink. i think you can get them through Jegs or Summit. good luck!! :2cents:
