HEI Distributor---
alwayscode390
pppssssshhhhhtttttttttttt
I was wondering if there was a "stock replacement" HEI distributor on the market? If so please link me , thanks ---
Captain Morgan
Moderated User
Re: HEI Distributor---
uhhhhh, its not like SyTys originally came with points or something. Changing the distributor isnt going to do a whole lot since all that makes it up is a cap, rotor and control module.
The coil is external and many will tell you that the stocker is fine for almost all applications. You could invest in some MSD add-ons to get a hotter spark, but thats about it.
wantingasy
I agree. There's no need to upgrade the distributor. We don't have the built in coils like on silverados or a lot of other cars. Just upgrade your stock coil to a msd and add a msd box if you'd like. I have the Msd coil on right now and I also have a 6AL box that will be going on shortly so hopefully I'll see some improvements with that.
Zewerr
ToeJam is a Poindexter
Actually, technically, our ignition systems are HEI, they just don't have the coil in cap. But they still use an E-frame coil which is pretty much the same coil. So only difference it would make is relocating your coil.
