Hello can someone please read this file
chevy110
After putting a new exhaust and a changing the ic pump and hot wired ( i think there might be air its a johnson pump and i see no coolant movement at all), also starter, both torsion bar bushings (both where just flopping around. Big difference!) front swaybar and new tires she runs a lot better. I am still however getting 7.9* of knock and i dont seem to be making proper boost. Truck is pretty much stock. Person i bought it off of said it had 50lbs inj atr chip and was in great condition and had a rebulit .30 over engine in the last couple of years. Stock chip stock inj (im pretty sure) and not very good condition so if the engine was rebuilt .30 over? I couldnt figure anything out could you guys give me a hand thanks
http://www.mediafire.com/?uardwemw9crucya
Re: Hello can someone please read this file
Atr never made a 50# chip on stock injector and 40# chip.
chevy110
Yeah thats what im saying the guy was full of shit so i cant say if the engine was rebuilt .30 over or not. i dont know if this would affect fueling.
Also if you don't see the coolant moving in the upper IC usually a rubber hose has a kink or air bubble in it. You need to get that working properly.
Can you take a picture of your injectors? Also pull the ECM and see if it's Atr chip.
chevy110
hello i pulled the ecm its just a regular chip, as for the fuel injectors ill do that tommorow or monday as the truck is at the shop.
chevy110
anybody? Id like to get her running properly before the winter gets here thanks. :D
sychris
your getting good boost 15 psi . it looks like your getting your worst retard at 15 psi of boost . i thought the factory was only 14.5 psi ? even at 4100 rpms the knock looked good but only 10 psi before the shift . dont push it
