Help ASAP
kessler
Ok i just got the motor back in and do i ever have a weird problem
My Spedo revs up with the engine in Neutral and when i turn the head lights on it goes up to about 50mph, The tach works good up untill 3krpm and then it hits 5-6rpm.
I also have code 22 poping up.
I have changed all the grounds around and it still does it. WTF is going on. I also did the ECU rewire still nothing.
Jimmy
Banned
Re: Help ASAP
Check the wires on the DRAC?
ViciousV6
400HP/550FTLB
Re: Help ASAP
white box sits on the back of the computer, controls the speeedo functions with the tranny.
kessler
Re: Help ASAP
But would it give off a code 22 ???? And would it screw with the Tach as well
sly dvl
Ya, it's got a Turbo
Re: Help ASAP
MaxTTY said:
Please let us know, You never know who will need that nugget of info.
Digital Ratio Adapter Controller - used to calibrate the speedo for different models.
Jimmy
Banned
Re: Help ASAP
I don't think it would throw a code,but I do know it will make the speedo act screwy.I think it's the blue wire that goes into the DRAC that needs to be checked.
Code 22 check grounds and ECM connections.Tach is probably ground related/voltage.
Flyin Ryan
hated cuz he drives fords
Re: Help ASAP
Have the same problem... speedo goes as it pleases even when in park.
I just got in from completely cleaning and redoing all my grounds.. fired it up and haven't had the issue yet so we'll see.
If you find the issue with yours please post it up because I may need it :)
kessler
Re: Help ASAP
Well i have changed grounds and i still cant get it so im going to buy some more wires to help with the grounding of the motor, And take it from there. But as im driving it today i sprung a leak, It was the damn power steering pump. I wish it would of leaked before i put the motor back in.
I also haven't been able to get the TPS sensor code to stay gone. So ill add a few grounds and see if it fixes it before i spend $70 on a new one.
