help bigger turbo need intake
1SLOSUV
so i just put the syty51 on my typhoon and i am trying to figure out how to get my pipe from the turbo to the aftercooler. the stock pipe wont work. any input? also i need a really short 90 degree silicone 3 inch hose for building my intake for cai. oil cooler lines are in the way any input? and i cant get the manifold to turbo bolts on because the nuts hit the housing on the turbo is there a fix for that?
________
Toyota Levin AE85 picture
Flyin Ryan
hated cuz he drives fords
Re: help bigger turbo need intake
Many people pickup a radiator hose with a bend on it that will work for you compressor housing to ic connection.. cut it up and trim to fit.
You can get pretty much any silicone hoses you'll need at http://www.siliconeintakes.com
Also I think your talking about the stock trans cooler hard line by the turbo inlet that's in the way right? most either bend it out of the way as best as possible, cut it and attach a braided line so you have enough play to fit a tube through for the intake or others delete it by running there own trans cooler since the stock in rad trans cooler blows at best anyways
about the bolts.. I have no clue sorry
Tooky
Serious about performance
I just answered this for someone else with the same question. Check this post: http://www.syty.net/forums/showpost.php?p=503032&postcount=17
Autozone radiator hose #304.
The oil cooler lines, you need a brass 90* fitting and bend the lines to fit. Find/search the right thread and check your local hardware stores maybe. It's all a real bitch fitting the intake in there. I have no idea what people do with the turbos with the 4" inlets! I've seen plenty with no filter :crazyeye:
I also had the same problem as you on the turbo nuts. Some "bolt on kit", eh? :roll: I had to grind the sides of the turbine housing to allow the nuts on. Shifting the turbo forward and back also helps to get the nuts started. I seated mine with the flange aligned to the front edge (nearest the radiator). Dead center is a little back from that spot, though.
