Help choosing new turbo
wildphil
I Love My Ty's
Looking for ideas.
Typhoon has ported L35 heads, 412 cam, 60lb injectors, 52mm throttle body, I have a Yank converter. I'm not sure what it stalls at probably about 3000 to 3200.
Must be able to keep A/C.
Almost all street driven. Will rarely see the track.
Was thinking PTE 6132 or 6176.
Any ideas?
TYTILIDIE
METH HEAD
Re: Help choosing new turbo
Looking for ideas.
Any ideas?
What do you have now?
Icarus-54
Donating Old Member
Try a PTE 6265,air cooled.dual ceramic ball bearings,super quick spool up,good for about 700 hp.
wildphil
I Love My Ty's
Well I bought the turbo used and was told it was a PT44. It is a oil and water cooled turbo so I guess it has ball bearings.
I already have the PTE downpipe. I would like to have a turbo that would bolt right up if I get another turbo.
One of the problems you going to find is that last I heard PTE discontinued the SyTy 0.85 housing. So you will either need to find one used (turbo /exhaust) or use the one off your PTE44 if your planing on using the PTE downpipe. I think the old 6152 or new 6262 would be a good turbo for your combo. You could get away with journal bearing turbo with a 3000-3200 rpm stall.
I have a 6131bb, and spool real quick at part throttle, its undersized for my build, but I tend to like turbo's that are on the small more streetable side. Do you have any ET or HP goals?
wildphil
I Love My Ty's
I was wondering if I could get a piece made for my downpipe to bolt to a v-band exhaust housing?
A think a journal bearing turbo would be fine. Everyone has been talking about how good the ball bearing turbos are is why I was thinking about one.
On the ET and HP goals. I don't really have a goal. Just wanting to see if there may be a better turbo for my build.
I don't plan on any more upgrades to the motor. So if I change the turbo that will be it for parts.
Then I will do my best to get the tuning set for the alky and timing.
If I can get it running at its best for the mods it has. I'm sure that will be plenty fast enough for me.
qbnkiller
Conflaguration Specialist
I run an unconventional combo. Its a Bullseye Power CompR62 turbo. Journal-bearing design. This makes it economical to buy and rebuild in the future. This is tBEP's own combination that performs extremely well. I run a home-made DP with an external 38mm WG - you can find pics on syty.new somewhere..I am a bit lazy ATM.. This turbo moves enough air to get a 4,000+# Ty into the 10's at 23#.
HTH...
wildphil
I Love My Ty's
HTH...
Thats great success. Let me look for those pics.
viperman5
PTE early this year had a Buick tech session in the Chicago area. Patrick, sales guy, was there presenting.
I spoke to him specifically about the SyTy with the air cooled dual ball bearing setup. He told me to call him directly that he believed there were still SyTy exhaust housing. The brochure still had the SyTy's mentioned in their 2010 catalog.
PM me or call Precision and ask for Patrick, tell him you were referred from a Chicagoland Buick member and SyTy owner to call him about turbos for the SyTy. 6265 is rated at 685 and he mentioned that turbo would be awesome for our trucks.
If you get a PTE turbo I would probably recommend that you get a billet wheel turbo whether you go ball bearing or journal bearing, it comes down to how much money you can spend. Based on ET's on the Turbo Buicks, the billet wheels appear to make more power over traditional PTE turbos.
Keep us all in the loop on what you decide.
Icarus-54
Donating Old Member
The 6265 I just got has the sy-ty turbine housing and also the billit comp. wheel.This thing spools incredably quick and I have 2800 stall 9-11
Jack
wildphil
I Love My Ty's
It looks like I will be buying a 6765. I got in touch with Mike at RPM and after I informed him about my build, goals. He indicated he would run the billet 6765. So I decided to go with it.
It will probably be 2 or 3 months before I pick one up. I will let you all know how the turbo works out.
