Help, getting code 43 - ESC Failure. What's this?
mrweelr
The last three times I've hooked up Datamaster, I've had the check engine light come on intermittently and Datamaster shows a code 43 - ESC Failure. When this happens, the ECM sets knock retard at a fixed 4 degrees. I'm totally stumped here. What is causing this error? This sucks! On a lighter note, the SMC alky kit with 70/30 denatured/water mix is keeping my KR under 3 degrees on 91 octane. Without it, I get up to 9 degrees of KR and I can even hear it audibly, yikes.
mrweelr
OK, I searched through the archives and it looks like this is a knock sensor problem. I just replaced the knock sensor a few weeks ago with a brand new one from http://gmpartsdirect.com. The part number they sent me was 10456549 and it looked exactly the same as the old one. Is this the correct sensor for our trucks? Lame...
KGB Pilot125
do you have a manual? if so check out code 43 in there it gives you step bu step instructions on testing it. it could be you ECM that is faulty. oh and syty.org code 43 trouble shoot is wrong. I sent em a few emails regaurding it but never heard back. If you dont have a manual let me know maybe I can get the one here scanned and sent to you.
now that I am thinking about it, have you tried a different ECM? I know you mentioned something about it before with your knock problem? Do you need another that works? My roomate has 2 of em one for Ty and one for Sy so maybe I can talk to him. Dont know how many SyTy guys you have in your area but basically our house is Idaho SyTy :D
nightdiver
Code 43 will set when:
1) coolant temp is over 90*C
2) MAT temp is over 0*C
3) high engine load dased on MAP and rpm
4) voltage on CKT 496 ( wire to knock sensor dark blue) goes above 3,5 Volts or below 1,5 Volts
5) all conditions present for 5 seconds
All this came from the MANUAL
mrweelr
I just checked the knock sensor for tightness and it's definitely not loose. I also pushed the connected on but it was down as far as it would go. The blue wire looks fine too...I'm stumped. I guess I'll just replace the knock sensor again since I never saw this error before I replaced it :( Is 10456549 the correct part number? I want to try a different ECM. If anyone has a known good one, please let me know.
Loeryder
Sy Ty Knock Sensor GM # 10456031 - may be an old number.
Email Dal and ask him what the updated number and cost is.
That and the full testing procedure of all the trouble codes can be found on www.sytyauthority.net
Tips - Diagnostic Trouble Codes
Hope this helps!!
mrweelr
That part number is not recognized at http://gmpartsdirect.com. Who is Dal? Someone must know what the correct part number is!?! I drove the truck to work this morning and beat on it pretty hard. No check engine light came on but I'm not convinced the problem is fixed.
Tydriver
TurboLS6 Powa'
Dal Slabaugh... He's the MAN, he's been selling us SYTY parts for years, he's been also selling them at LOWER than dealer prices (IE same prices as gmpartsdirect.com) Only he's not whacked out on the S&H the way that gmpartsdirect.com is.. He KNOWS his stuff.. Alot of the Buick guys buy from him as do the F-body boys... ORDER FROM DAL YOU WONT BE SORRY.
heres the website but its kinda cheesy http://vandevere.com/
Better yet.. Call and ask for him 1-800-362-9494
mrweelr
I searched through the archives some more and it looks like #10456549 is, in fact, the correct part number for our knock sensor. I'm going to order a new one (again) just to be safe. I'll try ordering from Dal this time 'round.
Thanks
mrweelr
OK, here's an update. I pulled the blue wire off of the knock sensor and turned the ignition on. Tested it with a voltmeter and I'm getting 4.94 volts stable so CKT 496 is good. Then I took out the knock sensor (it was only hand tightened) and cleaned the threads to bare metal. Also cleaned out the threads in the block really well. Then I reinstalled the knock sensor and tightened it with a ratchet and socket this time (not overtightened). Disconnected the battery for a few minutes to clear the code and drove the PISS out of my truck using Datamaster. Result - no more check engine light or code 43...yahoo! :D I did a bunch of runs with and without the SMC alky spraying and I could not make the code come back on. This was a 30 minute drive with at least 20 WOT blasts up to 90 mph. So I'm really happy now that I fixed that problem. The SMC alky/water mix keeps the KR at about 5 degrees or below with some spikes here and there but that's on straight 91 pump gas. One thing that I tried when I got home was to stab the throttle a few times while idling in neutral to see if it would knock. To my surprise, I'm getting up to 5 degrees KR by just punching it while idling (boost under 2 psi) :eek: I don't know if this is normal but I'm really starting to think I have at least some false knock. I'm gonna' pull the plugs and read them with a magnifying glass next to see what I find.
