HELP! hopefully valve lash
Bullit4300
Okay I will start my story by explaining how this became the other night I went for a cruise, picked up a few races since I put in the Hypertech chip this truck runs like a dream. Now the next morning I started it up and oil pressure went to middle like it usually does and moved up and down normally, I went under hood revved up engine to about 3000 or so ( telling by the sound) all of a sudden I hear this tick tick tick noise that remains constant. With my Stethoscope I probed the right valve cover and the tickings the loudest @ that point sounds like the rockers came loose, my question is! does this sound like valve lash? or something worse I would like to know how to tighten then rockers back down if so, engines still running strong with lots of power this noise gets louder when revved any input would help a great deal
Bullit4300
Re: HELP! hopefully valve lash
yep stock heads stock internals pushing with chip & adjustable boost control roughly 18 - 19 psi
bezerk
pull the cover and check, or pull the wires on that side one by one and see if it goes away
Bullit4300
Pull spark plug wires okay will try that as for rocker stud I believe its possible to have backed its way out will get back wit results
DaveP
I highly doubt it pulled a stud with stock cam and valve springs. And it sure didn't pull a stud free-reving it to 3,000 in neutral.
You said the noise suddenly came on after it was already running. Not on cold-start after a night of abuse. (Racing). something happened after it was started. Like a piece of debris got caught in the lifter.
My WhiteTy developed a lifter clack on cold start during the Maine trip. Every morning one lifter would clack away for up to a couple of minutes, go away, and would be silent for the rest of the day. This most likely isn't your issue, but it was for me. I changed the oil. It had been over 8,000 miles since the last change. The noise has never come back.
Bullit4300
So DaveP your thinking it could be bad oil causing this problem yeah I took her out for a night of going rough but not severly rough it sounds like a clacking noise and it doesnt seem to disappear
DaveP
No such thing as "bad oil". But there is such a thing as "dirt IN the oil".
When you rev'd it with cold oil, the filter by-pass in the block was forced open, and any debris that may have settled in the pan during the nigh went right into the engine through the by-pass without being filtered out. This little chunk got caught in a lifter, and is preventing the lifter from pumping up properly, and that one valve train is now loose and clacking.
I don't know if an oil change will cure it. But I'd sure try it. And then drive it kinda hard-ish with warm oil and see if the noise cures itself. If it doesn't after a few miles you're going to have to pull the valve cover and investigate.
I like my dirt theory better than a pulled stud, based upon the conditions under which it occured.
Bullit4300
yes this is true for now I will leave her parked until I get some new oil and do a change
Buy a set of "stoppers" (little clip-on gizmo's to cover the oil hole on the pushrod end of the rockers). Remove valve covers, install gizmos and start engine. If it gets noticably louder it's prolly a rocker/lifter. Get feeler gauge and slide it under each rocker untill noise goes away (or diminishes) if so you found the culprit. Now lay a straight edge across the rocker studs and see if that one is pulled. Otherwise it's the lifter or something else. Not necessarily fun but it does help narrow things down.
One question though: Has the oil pressure changed since this happened?
Slyclone
Well-known member
Hello- I wouldnt reccomend any more reving/starting untill you can pull both valve covers, visually inspect and than put your hand on each one and wiggle if one dont already stick out.
You know what I mean?
I recently had a clack on a chevelle and had to shut down immideatly. Problem that time around was the rocker arm had developed a crack and exploded the bottom of rocker out.
I had a replacment OE style rocker laying in the tool box and put it on and adjusted it. Pulled the car out for a show last week and wouldnt you know the same rocker went.blew right out the bottom. I inspected the oiling during engine running and the OE style rocker had a smaller oil orfice and no galley. I believe it was a SUMMIT brand rocker. I believe the rocker installed on the car was a poor design and the oil was insufficent and caused some friction. (just purchased the comp mags)
Some of thses engines share the same noises. I would think that the noise your hearing is a rocker let loose. Are they original? upgraded? ever check them out?
Bullit4300
last time I had that valve cover off was when I replaced the gasket that was a while ago now but when I did take it off yeah they look orig I will see if I can pop it off this eve after work
johnboy89
hi on that thread no one explained anything about it being bad whats wrong with that chip I am asking cause it may help me diagnose this problem going to pull that chip tonigh too
I personally have never used one of those "Hypercrap" chips as I've seen them called, my info is from others who have ran them on here. If you search on it you'll get plenty of info.
My advice would be to have hood burn a chip specifically for your truck. The deal is you send him your chip and he will burn it or you could just put the stock chip back in!!
BoostedSUV
I agree with with everyone. Although you rarely see a rocker lossen up it is possible. I chased this issue with my truck for a while when my rockers kept "lossening up". Well it turned out the rocker studs kept pulling ever so slightly out of the head. In my case I had 1.6 rockers and a bigger cam. Although I agree with Dave that it unlikely a stock engine lifted a stud under those conditions, it would be something I would check.
On a side note, do you have a WBO2 or Datamaster? If you don't invest in one because running 18-19 psi with a hypertech chip its a safe bet the next click you hear will be a rod knock. Don't learn the hard way like some of us have.
Bullit4300
thanks for the info guys the funniest thing this morning I started it up twice and both times there was no clack sound personally I think I have a gummed up lifter i will go with the simplist way to solve the problem then if it persists I will step to the next level engine has lots of compression lots of oil pressure I think she just needs a lil love lol :p. As for the boost yeah the laws here about racing to tunnel vison are very much frowned upon so I i just turn her boost down to 15 - 17 besides not many ppl challenge me around here too many are either scared or don't know what it is LOL
Could very well be true. Depending on where my motor stops the next time it starts it can be very noisy for a few seconds. It varies from a little to a lot. Obviously lifters since it's been doing it for a few years now... Comp lifters before anybody asks.
