Help Identify My Chirp!
phoonTy
Truckless. For now.
My Ty has recently developed a "chirp" which is loud and quite annoying. I have a stethescope and stethed everything I could touch with it in the engine bay, truck running, and here's what I know:
It's not one of the following:
- Any of the accessory pullies... ie, waterpump, power steering, idler, tensioner, ac condenser, crank pully, alternator pulley
- We also stethed the valve covers, throttle body, intake, turbo, various spots on the engine, don't hear the chirp anywhere.
- Jacked up the truck, stethed anything and everything we could get to under the truck on or near the engine. Nothing.
The chirp is too slow to be a pulley, or pulley bearing. It's rythmic as well. I'm at a total loss as to what it could be.
Here's a Vid (4.25mb) with the chirp clearly audible, in quicktime format:Right Click Save As
I don't care if my engine is about to blow, I just need to know what's making that sound so I can start going about fixing it. :(
thanks
phoonTy
Truckless. For now.
well, fan clutch is one i hadn't thought of. the belt is only about a month old, so i don't think it's a worn belt, although for $15.00 and having an emergency belt, i could try it. I'll have to check out the fan clutch as well. thanks for the responses... the hunt continues, with direction! ::thumbsup::
phoonTy
Truckless. For now.
ps... anyone got recommendations for what to get? I searched, and I know not to go with the Hayden heavy duty. I'd prefer a stocker anyway.
anyone got a part # for the stock fan clutch?
I found this pn for Autozone: 215142
good bad or ugly?
phoonTy
Truckless. For now.
i need to do the brake booster check valve as well... got the duck. anyone have an Autozone cross reference part number? I've tried the pn from SyTyAuthority, but it doesn't pick anything up at Autozone. A checker pn would work as well, they are both close to me.
phoonTy
Truckless. For now.
well.... sorta. haha. so i'm out driving it tonight, and what do you know? more underhood noises.
so.... I think the original noise was the fan clutch. problem A solved. Now, I think it could be the belt squeeling, as the noise has changed...um...tempo. it sounds more like a belt squeeling now, and it goes away at idle, which the "other" noise didn't.
i bought another belt at AZ, even though I just put one on when i did the power steering pump, so if all else fails, i'll have an extra belt. problem is, i think AZ sold me the wrong belt. Someone correct me if I'm wrong, but the Kelly Springfield part # is 952K6 i was in a rush and couldn't remember the # off the top of my head and just went with their computer.
but don't worry jimmy, you still get your stickers. :) unfortunately i had to work over-time today, so they'll be on their way tomorrow. ::thumbsup::
