Help identify this part for me please!
jjorgensen52
NHSTE - I'm the only one!
Re: Help identify this part for me please!
To me that looks like a thermostat gasket. Just a guess though.
ty166
looks like its made out of metal and shows some wear marks.
SeattleSy#1255
Category 5 Conservative
is it a gasket? maybe for the dissy, but probably not the holes wouldn't make sense. What is it made out of I can't tell?
TurboTony
autoaddictions said:
What the hell is this and where does it go???? Anybody know. Its out of a 92 TY
Camshaft thrust plate, bolts behind the cam gear, should have two button head toex bolts to hold it onthe block.
Tony
autoaddictions
Tony
I didnt assemble the short block my builder did i dropped off all the parts to him . Whould a new 422 comp cam kit come with a new one?? I hope so or that bitch isnt in there.
jjorgensen52
I recind my prior remark and my license to identify stuff :oops:
Points taken. For some reason that part looks very familiar to me, but at this point I have no idea why.
James Thomas
"NO CLASS"
Ditto on the part description and you better make sure / check your builder not only if it is actually installed but that the correct one is indeed installed because there are two designs, early and late for balance and non balance shft engines!
_____________
James
Loeryder
Agreed.
I bought a new GM plate for my Comp 412 just haven't put it in yet.
If they do include one with the cam I wouldn't trust it, I would get the correct GM part #.
autoaddictions
I called him today and asked if it was in there he said he would,nt have not put one in.If i was paranoid try to pry on the cam through the distributor hole and the cam should not move at all. If the plate was missing the cam could move forward so he said. I realy dont want to pull it apart but now i just might have to. Ill be pissed if i blow a 6000.00 motor.
jjorgensen52
THis is true, the cam will slide forward without it. Most likely just replaced it, seems to me that parts for the cam are replaced all at the same time.
